SpreeDio official GPS 63.6 MPH stock pipe, stock carb +Video
ped
Post by ped »
https://www.youtube.com/watch?v=BZr46_-douQ
Hi forum. Take a look on page 2 for new GPS photo below May-15-14.
Hi forum.
Finally some warm weather for the spreedio test run.
I set the GPS speedo on the phone and put it in my pocket.
I went for a 11 mile ride. when I stop to check top speed, 60MPH.
the ride was mostly flat except one slight hill. will retest on flat only soon.
*the spreedio
Af16 swap
Rumina stock crank
8.4
TT temp gauge (401 max)
Pre mix (oil pump plug)
Stock exhaust pipe. (drill out washer)
Stock carb (91 jet)
stock mani, reeds, air filter
old stock belt (slipping)
stock variator
stock rollers (8gm I think?)
stock tire 3.00-10
stock rear springs.
ped
Re: SpreeDio Unofficial 60MPH stock exhaust pipe, stock carb
Post by ped »
the spreedio.
ped
Post by ped »
hi forum.
The spreeDio was very stable at high speed.
I felt comfortable at that speed, or higher speeds. ( I'm 175 lbs.)
I took the PG Short off because it's to loud. ( no high speed testing done)
I took off the 24mm oko because the small spree gas tank, and gas hog. ( no high speed testing done) plenty of power.
I am still breaking in the polini corsa.
Great result. I just hope you don't have to stop in a hurry from that speed.
ped
Post by ped »
Wheelman-111 wrote:Greetings:
Hi Wheelman.
That was just a test run. I have the new metro brakes just have to install them.
First time all year we had good weather for testing.
deuce217
Post by deuce217 »
Cool ride. Is that plasti-dip paint?
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
So you've sorted out installation of the 95mm Met hub on the Spree forks? Pics, man, PICS!!
ped
Post by ped »
deuce217 wrote:Cool ride. Is that plasti-dip paint?
Hi deuce. It's heat paint. flat black.
ped
Post by ped »
Hi wheelman.
I have something a little better. take a look :shock: .
The metro wheel and forks. for a swap.
The met hub spree forks works.
ped
Post by ped »
Hi Wheelman. :hi: :hi: :hi: :geekdance:
I dont think anyone has posted this adaptation before. I believed it could work because the Spree forks telescope like the Met. Not having built a Spree myself, never got to test the theory. Well done. The Dio-powered Spree needs all the stopping power it can get!
Dio89Elite
Post by Dio89Elite »
^^ that's so true. A lot of people often neglect the stopping part of the upgrade equation...
Ped: nice build, thanks for sharing!
LMH
Post by LMH »
That looks awesome! Id be scared of melt down from the stock pilot though but if it works it works. Funny enough I run 1 jet size smaller for my stocker thanks to the intake, reeds and exhaust. Keep her stockish as long as you can and enjoy the good MPG!
ped
Post by ped »
Hi forum
Thanks graphite, wheelman, Dio89elite, lovemyhonda, everyone.
The brakes work great. a lot better then the spree brakes.
The tire size is 2.75-10.
Any bigger tire will rub on the spree forks.
I think I'm going to change them to left side. because Honda made the brakes for left side. and my wheel is facing opposite side.
I have to get a longer cable. but everything works fine.
Hi lovemyhonda. max temp peaked at 401. when let off gas.
I will adjust the air fuel mix, as I'm still testing top speed.
I will use the TomTom GPS for next test.
ped
Post by ped »
Hi forum.
I have photos of the metro brakes on the spree.
but cannot post them.
I get this massage: Sorry, the board attachment quota has been reached.
It looks like the forum won't get to see bigger brakes on the spree?
and the 60MPH test results.
