My 87 Elite 50 125cc stroker Build..
Hppowdercoatings
Post by Hppowdercoatings »
Picked this up from a buddy that did not have the time or Money to finish. 561 original miles, I'm Third owner. This is my First 2-Stroke scooter build.
Engine mods so far:
1994 AF16E
Autotech355 Monster Upgrade 125cc kit.
54.00 mm bore
52.60 mm Stroke
Engine was Disassembled , Cases Machined and Reassembled by Jed's Cycles in Jerseyville,Il.
30mm Carb
Performace intake
Intake & Exhaust both have Port work..
V8 Pipe - removed the Blue and Powder coated it Gloss Black.
I'm going to run it on Premix E85
I still have to pick up a performance Clutch & Variator Kit.
Also have to get a shorter disc Break hose..
So far I have tore it down to bare frame.
I removed the Stem out of stock tripple tree.
Had an extra gy6 disc brake front end I stripped down , welded in the stock Elite stem then powder coated the tripple & forks Gloss black.
Removed and Powder coated both engine Covers and Kickstarter.
Installed new Black Seat cover.
Took the stock front wheel and Cut out the Drum hub part and made & welded in a Steel hub to mount the Brake Disc. Then Sandblasted & Powder coated both wheels White.
Then mounted New BridgeStone 2.75-10" Hoop H01 Tires
Cut the Stock Engine mount and gave it a 4" stretch.
Did away with Stock rear shock and made a solid strut mount out of 1.0" Sq Tubing.
Couple pics of Scoot when I picked it up.
Last edited by Hppowdercoatings on Mon May 12, 2014 5:18 pm, edited 4 times in total.
Hppowdercoatings
Re: My 87 Elite 50 125cc stroker Build..
Couple updated pics..
Hppowdercoatings
More..
Hppowdercoatings
Couple more..
Hppowdercoatings
Couple mock-up pics .. Still need to do some paint touch ups and some more wet sanding/buffing. Just finished the Quick spray can Black paint job.
Hppowdercoatings
Desided to lower the Front 2" so I cut the Spring/Stops..
deuce217
Post by deuce217 »
Looking good man. Have fun.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
jareeb
Post by jareeb »
you can get e85 to get along with 2 stroke oil? i heard that they dont like to mix.
1985 spree 40qmb swapped w/bbk (in the works)
Hppowdercoatings
jareeb wrote:you can get e85 to get along with 2 stroke oil? i heard that they dont like to mix.
Yes here are a couple..
castor 927
Klotz techniplate
ped
Post by ped »
SWEET. Nice work.
Hppowdercoatings
Pic of new Decals.. I have to finish wet sanding and buffing side panels then I will post pics of them.
That looks Great! I really like the "49 RR". Priceless looks on motorists in traffic when I smoke... -ahem, Literally - them.
Hppowdercoatings
Still waiting on parts and need to finish some wiring. Finished Spray bombing the plastics and put on the New Decals..
Dio Dawg
Post by Dio Dawg »
Nice ride too bad you had to cut your inner panels.
Best-looking scooter I've seen in a while! Are you clear-coating over the decals, for the Cherry on the Parfait?
But is that a bare-nekkid cooling fan I see? I sure hope your're not running Shroudless!!
