It is the tiny passage from air mix screw>brass pickup tube in bowel>tiny exit hole in high velocity part of carb (I can remove the air mix screw completely with no change in the way it runs. I think it is clear going from air mix screw and exit point in neck of carb, but the brass pick up tube part of the "T" passages (to fuel bowel) is still plugged (I put a vacuum gauge on it and after creating a vacuum, the vacuum holds steady).
I am going to let if soak for several days in Acetone, any suggestions?
Oh yeah... this is on a 1985 Honda Spree 50cc
Is there supposed to be a clear passage between passage A and brass tube B? When I apply a vacuum at brass tube B it will hold a vacuum with no leakage shown on the vacuum gauge (so its clogged I assume)
