I own a building downtown that I rent out to a company that produces tires for the fork lifts, if you ever need new ones pm me first Ill see if I cant get some for free. Fork lifts are so easy to work on.
LoveMyHonda wrote:I own a building downtown that I rent out to a company that produces tires for the fork lifts, if you ever need new ones pm me first Ill see if I cant get some for free. Fork lifts are so easy to work on.
Lovemyhonda, I need some of those! The rear drivers side is cracked in half! It is a clark c500 that would be amazing.
Graphite,
I figured as much. The funny thing is I cant find a single dude around here that is really into fabbing. Its weird, everybody that comes to my house does not even have interest in the shop. Losers. lol
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
Malossi Delta Clutch & WIng Bell- Thanks RED EFT 65mph GPS (on the freeway)
6.5x10? or 10 x 6.5? I dont know what he said. He said he can get them for sure just let me know what it is. Do you have a local shop that can mount them?
LoveMyHonda wrote:6.5x10? or 10 x 6.5? I dont know what he said. He said he can get them for sure just let me know what it is. Do you have a local shop that can mount them?
Front tires are 6'' wide ID of 11 3/16'' or so outside diameter is currently about 12 1/2
Rear are marked CLARK 14'' x 4 1/2'' x 8''
Thanks,
Veedub,
Gotcha.
50mm BBK (tai)
V-8 pipe
Nice
BTW - The table has wheels in the first pic but not the second. Makes it look that in passing by the welder and angle grinder the wheels dropped off
You are killing me! You should have been a sniper. I am thinking you have hondaspree.net on a projection screen. I had the pics backwards, I did not think anyone would notice. Duly noted...
50mm BBK (tai)
V-8 pipe
