I picked up a 1985 Nifty 50 from down the ways for a crisp $60 a couple of months back, and during the last month (been on call for work, phone hasn't rung much!) I set about bringing her back up to spec... plus a few added specs thanks to Taz.
[/URL]
[/URL]It had been sitting outside but under cover for most of the last 13 years since it was de reg'd. Missing were both side panels, headlight, and a few other minors. Managed to source all parts before setting to work. Finding the round headlamp was a b****, but managed to stumble across one that slid into the hole just fine.
The frame was in good nick so gave it a quick rub down and a nice coat of primer to keep it that way. Oil tank was more water than oil,
so good clean out for that and the fuel tank.
[/URL]A few hours with a multimeter and test bench saw the electrics come back to life. Much of the +ve wire from battery to key was toast, so I bypassed it along the loom with a nice new one. Easy fix.
[/URL]Wire drill brush and a few tedious hours saw the wheels ready for paint.
[/URL]
[/URL]New engine parts in, 48mm taz kit...
[/URL]...and 21mm carb kit. I've run a manual choke cable as well so you can choke her whilst sitting down. (not pictured) I left the oil pump hooked up in addition to running 32:1 for a few tanks of gas during run in. Last night in fact I removed the pump shaft and blocked off the ports, will continue to run her on premix only.
[/URL]New panels arrived, sized them up to clear the new induction setup. Also added a Westach CHT gauge and knockoff tinytach/hour meter.
[/URL]Everything into plastic adhesion promoter, and primer/paint. Got a nice blueish grey mixed up and shot it with my automotive gun, gave a nice flat air-force ish colour.
[/URL]All finished, and ready to run in!
[/URL]The reason for the colour should become clear about now - ref decals. The story behind it is simply that I got the helmet in Bali about 9 months ago, and planned to do something RAF based ever since. Some of you should recognise the carrier on the back as a 50 BMG ammo tin that I scored for $10. The tubes on the back...
[/URL]...rod holders
[/URL]She runs sweet, not too quick at the moment as the jetting is purposely rich for running in. In fact I'm only seeing 300 deg F on straights and just touching 350 up hills, and that's with a 6 heat plug. Towards the end of the week I've got an MLM pipe, new belt, and some jets arriving. Then let the tuning fun begin. All i'm after is a solid 52 - 55kph and I'll be happy. The purpose of having it is running around our local area (just out of Auckland) and for the two scooter safari's we have here in Enzed, so call it charity work.
For those not familiar...
http://www.centralplateauscooterchallenge.co.nz/ <= North Island, Wanganui to Taupo
http://www.scootersafari.co.nz/ <= South Island, Christchurch to Hokitika (over the southern alps!)
Just need another scoot now, because the Mrs is all keen. Thinking fire engine based, as she is a volunteer firefighter.
