oil leak question
Rip_City_Spree
oil leak question
Post by Rip_City_Spree »
was replacing my exhaust gasket and saw there is oil gathering on the hole in the picture and not sure where it is coming coming from and thoughts guys?
oil scooter.JPG (179.79 KiB) Viewed 4124 times
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
jetspinz
Re: oil leak question
Post by jetspinz »
Give the area a really good clean and scrub with brake cleaner and go for a ride. Might be as simple as some oil you spilled a while back. If not, then with the area clean you should be able to see where its coming from.
Rip_City_Spree
Yeah I cleaned guess the better question is what is that for?
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
paulpauly7
Post by paulpauly7 »
is this a se50 motor ? If so the japanese models like the dj1r have a extra mount holding the exhaust .Pull your fan cover see if theres oil splatered around the inside if so it could be a crank seal
Dio89Elite
Post by Dio89Elite »
exhaust gasket leak would be my guess too
Rip_City_Spree
I did replace the exhaust gasket graphite9 thought it sounded like it had a small leak. Wasn't cracked but old will check to see if there is any more oil this weekend when I get my rim put on.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Quoth Rip City:
It's hard to tell, and nobody knows LESS than I about Sprees, but isn't that the mounting hole for the cooling shroud? If so, there'd be a corresponding threaded hole in the crankcase unless it's not the shroud for that block.
