Honda DIO
85stroka
Post by 85stroka »
JakeTheNoob wrote:ok i got it. a 2000 dio, sk50, some of the plastic is messed up but i got it for 830CAN which is about 700US. everything works fine except...
the front headlight only works on highbeam.
the rear break light box is a bit cracked.
the electric start does not work.
does anyone know a good place to buy parts for a dio 2000? theres not much on ebay i think...
thanks
That would be a dio sr.or zx depending do you have disc brakes?
Remember,everyone is human,even if there stupid!
JakeTheNoob
Post by JakeTheNoob »
no i dont have disk breaks, but i think its a sk50m?
im not even sure if that exists but i think i saw it somewhere...
do you know a good place to buy parts for it?
85stroka
Post by 85stroka »
what does the sod epanel say -dio sr?
I order stuff from japanland,but there's alot of shops here in hawaii that carry parts for it? what are you looking for ?
The engine is basically the same as the elite S -sa50 other then the stator placement.So bore's carb/pulley/clutches would all be useable for you
