Deuces 450.00 Dolla halla Build 2000 Elite SR
kingkamehameha
Re: Deuces 450.00 Dolla halla Build 2000 Elite SR
Post by kingkamehameha »
Dont waste time porting that 50mm jug or matching the boost port or touching the intake window. Tune it correctly and run that cylinder until it craps out. Then go buy a mhr or corsa and match the boost port to that if you have to. Intake porting is hard to do and takes porting 3-4 blocks before you can really do it properly. In my honest opinion i wouldnt touch the block unless you have to. The corsa boost port is pretty close to stock its a bit bigger but not as big as the mhr or the 50mm. Bigger isnt always better. Its all about how clean your job is.
deuce217
Post by deuce217 »
kingkamehameha wrote:Dont waste time porting that 50mm jug or matching the boost port or touching the intake window. Tune it correctly and run that cylinder until it craps out. Then go buy a mhr or corsa and match the boost port to that if you have to. Intake porting is hard to do and takes porting 3-4 blocks before you can really do it properly. In my honest opinion i wouldnt touch the block unless you have to. The corsa boost port is pretty close to stock its a bit bigger but not as big as the mhr or the 50mm. Bigger isnt always better. Its all about how clean your job is.
I am looking for a old jug that has good porting done on it. I will be happy to pay for it.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
deuce217
Post by deuce217 »
Back to work here.
Delta Clutch, Wing Bell, and belt installed. No more slip.
I also got the net met rim on back with a kenda 453 90/90-10 sport tire
The process of putting the tire on the metro rim took about 10 minutes, this was my 1st time installing a tire on a rim. I just used some soap and warm water and 3 flat head screw drivers and some common sense. This looked like a monkey doing a football im sure but I got it done.
(other than about 1000+ bicycle tires when I worked assembling them)
Image I did not realize the old baskets were designed to fit two 1 gallon milk jugs.
50mm BBK (tai)
V-8 pipe
deuce217
Post by deuce217 »
So I was taking the old rear rack off and notice that the studs where getting flattened from taking it on and off so many times in the past. Idid the right thing and cleaned the threads out with a die.. What a difference it made. Image
50mm BBK (tai)
V-8 pipe
deuce217
Post by deuce217 »
Image Finally got my continental ZIppy 90 90 10 tire in. Now I am tubeless, and clueless.
50mm BBK (tai)
V-8 pipe
LMH
Post by LMH »
Youre going to love the conti, only tire I like more is the bopper and it doesnt fit our rigs. I need one of those baskets!
deuce217
Post by deuce217 »
Yeah, that thing is grippy as they get. Perhaps when I get time I will fab a few. Its hard to find these baskets now days.
50mm BBK (tai)
V-8 pipe
deuce217
Post by deuce217 »
New Speed record today on a decline with the new PG Short pipe on it!!!! Thanks Wheelman, I love it Image
Note:
I had really high temps when going up hill. I think this pipe likes a bit more main jet than the v8 required.
50mm BBK (tai)
V-8 pipe
Good Heavens, the Holy Grail!! 72MPH on 72ccs. Congratulations!! Sure some will criticize the "decline", but how many speed boasts do you think were generated UPhill?
ped
Post by ped »
Very nice deuce.
congratulations 72 on 72 cc.
:2thumbs:
the Continental Zippy's do stick very well when they warm up.
they look good on the shooter to.
deuce217
Post by deuce217 »
Thanks Wheelman and Ped. I have to admit that I do not have 72cc though. This bore is the 50mm thai bore from Autotech355, no boost port match, 7.5 gears, 90/90 tires, and a grin on my face. My corsa will be next, I will run the PG long on that one and gonna switch all my rides to 9-1 gears. I think the 7.5s might be a bit tall.
50mm BBK (tai)
V-8 pipe
Consider 7.97 and 8.44s between your 7.5s and the 9s. I feel the 9:1s are good for stock-ish power, but too short for anything more.
deuce217
Post by deuce217 »
Dang I have 3 sets of 9-1's
50mm BBK (tai)
V-8 pipe
Red Eft Performance
Post by Red Eft Performance »
deuce217 wrote:Thanks Wheelman and Ped. I have to admit that I do not have 72cc though. This bore is the 50mm thai bore from Autotech355, no boost port match, 7.5 gears, 90/90 tires, and a grin on my face. My corsa will be next, I will run the PG long on that one and gonna switch all my rides to 9-1 gears. I think the 7.5s might be a bit tall.
This is a good example of the fact that the boost port doesnt have to be opened up! :thumbsup: Ive been telling people for years that you dont "have" to match the boost port. Some people still believe the motor will fry if you dont match it.
Well Done
Keith
Red Eft Performance
View products click => Here
deuce217
Post by deuce217 »
Thanks Keith,
I really was not comfortable doing the boost port match back then. I would do it today if I did another. But Maybe the increase crank pressure is not a bad thing. I am interested to see what a corsa feels like compared to the tai 50 bore. I hope it spanks it. One of these days I will find out, too bad I am the only person in my county with a sr 50.
50mm BBK (tai)
V-8 pipe
