the one owner 2001 indy elite build
- cruzingratiot
Re: the one owner 2001 indy elite build
small update
been riding it the last couple days
with premium fuel
re gps it at 50.6
and been getting great mpg
right around 100 mpg crusin at 35 - 45 mph
been thinking may leave it as is
with premium fuel
re gps it at 50.6
Donate Life
http://www.donatelife.net/
Thank You
Thank You
Uhh, the scooter or the Falcon? Both look amazingly clean and in great condition!
- cruzingratiot
added metropolitan rims
will need to re gps
but I think the added rotational mass slowed up the top end of the moped
metropolitan brake arm is longer and fits the elite hub
made the brake lever move more to apply brakes
but the force needed to apply the brakes is a little less
and the cable pull is straighter with the metropolitan brake arm ?
see the white rim the cable goes upward
will need to re gps
Thank you the falcon is a ranchero body styleWheelman-111 wrote:Greetings:
Donate Life
Thank You
Thank You
Have you tried using a heavier clutch bell also? My bikes with the malossi wing bell seem to maintain that higher speed easier.
- cruzingratiot
right now it has a polini stock replacement bellLoveMyHonda wrote:Have you tried using a heavier clutch bell also? My bikes with the malossi wing bell seem to maintain that higher speed easier.
and a 3 shoe polini adjustable clutch
from the spare parts I have
if I get extra money I may try a winged bell
for future refrence 1017 miles on it now
Donate Life
Thank You
Thank You
- cruzingratiot
ported the stock intake
couldn't get any good pics
and added polini reeds
made a difference on mid acceleration 25-40 mph
Donate Life
Thank You
Thank You
- cruzingratiot
remember this is stock bore motorswimmingfree wrote:i wood like to see what his top speed wood be if he put a pipe on it now ...
9to1 gears , polini variator,, 2,000 clutch springs in stock clutch < took off the polini clutch I had on it
polini reeds, ported stock intake , 51.1 mph
I did try my PG short last summer
didn't GPS
with the PG it had no bottom end
you probally get run over up 20 mph it was that slow taking off
but after 20mph it took off really good
just wasn't ride able with the pg exhaust on it
tried messing with springs rollers ect
couldn't get it to take off
so the stock went back on
cruises good at 40 mph
the last long ride I went on it got 102MPG
1432 miles one it now
more to come ?
Donate Life
Thank You
Thank You
- Rip_City_Spree
Wish my 01 looked that clean the previous owner did not treat her well.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
kirt70camaro
What will the 9.1 gears do? More take off or more top end? I'm 200 pounds. I just bought a none running 2001 elite s. Has no compression. Would be real happy if I could get mine to run anywhere near yours. Not sure if I should just replace piston and rings or upsize. I don't want to spend a lot of money on it.
- cruzingratiot
the gears will give a little more top endkirt70camaro wrote:What will the 9.1 gears do? More take off or more top end? I'm 200 pounds. I just bought a none running 2001 elite s. Has no compression. Would be real happy if I could get mine to run anywhere near yours. Not sure if I should just replace piston and rings or upsize. I don't want to spend a lot of money on it.
derestricting it with stock gears it did 46.8
put the gears in it did 50.6
really think about what you want out of your scooter
you don't want to spend money twice
there is a big difference in acceleration and top speed from stock to modded scooter
this scooter runs good but it is a slug compaired to my purple elite
but still enjoyable to ride
Donate Life
Thank You
Thank You
Nice collection of s models, but my collection will blow your mind
Those are nice elites. He showed us his, now show us ''yours'' maddogmaddog wrote:Nice collection of s models, but my collection will blow your mind
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
I have a met hub; the kind with two brake cables. Im gonna pull off one of those levers and give it a shot. That straighter cable probably returns to home position better than its shorter counterpart.
98 Elite
4 strokes are for cars
- cruzingratiot
less effort more travel I like it for stock brakesgraphite9 wrote:I have longer aftermarket billet brake arms, just haven't tried them yet. Let me know how they work. I think you'll have more throw/travel required but greater leverage.
went for a 30+ mile ride with some friends
I wasn't riding it
we were riding the POP bike POP build link
my Mystic Purple elite Mystic Purple elite build link
and this 2001 elite
but when we got back he showed me his gps and it hit 54.7
it was last ride with me owning all 3 of the elites in the picture
was made a offer on the POP bike and sold it
specs
stock motor derestricted
premium gas amsoil dominator injector oil
polini variator 6,9 weights
stock contra
9to1 gears
metropolitan tires / rims
1534 miles on bike
Donate Life
Thank You
Thank You
