125cc stroker?
125cc stroker?
Having a water-cooled 125cc stroker built and sent to me. i am just looking for tips on tuning and maintenance or anything helpful. Previously all my builds have been 72cc that i have built new to the stroker game. Just want it to last. thanks!
- Downsouthdio
Re: 125cc stroker?
Get ready for some stuff to break lol..i broke a c├┤uple fans..but just run good oil everytime and make sure you have a temp guage..good luck..i sent my block to hawaii actually to get cut and have the bore and block ported..good luck!!
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Re: 125cc stroker?
Where did you find the 55mm jug? I could only find a 54 Lc cylinder for my 120cc Lc stroker build. I haven't started the build yet and if I can get a 55 I'd rather do that.
Re: 125cc stroker?
Did you use the autotech355 kit? Do you have a build thread on that motor?LoveMyHonda wrote:Where did you find the 55mm jug? I could only find a 54 Lc cylinder for my 120cc Lc stroker build. I haven't started the build yet and if I can get a 55 I'd rather do that.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
Re: 125cc stroker?
Jiangwayne is who I used for the 54, it's the china copy of John wayne. I'm still waiting to build it when I get time with everything else.
Re: 125cc stroker?
Maybe I can bore your case for you when you get around to it. I am dying to take some cuts on the new bridgeport. I should have it wired up this month. It takes 3 phase power so I need to wire the rotary phase converter still. Last weekend I finally got it put in its place in the shop.LoveMyHonda wrote:Jiangwayne is who I used for the 54, it's the china copy of John wayne. I'm still waiting to build it when I get time with everything else.
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
- Downsouthdio
Re: 125cc stroker?
You should have spent on minarelli jog wink! Here is the Taiwan 125cc crank blow up on Fb taiwan..
- IMG_21675342431264.jpeg (59.77 KiB) Viewed 7348 times
- IMG_21685267663197.jpeg (149.44 KiB) Viewed 7348 times
Re: 125cc stroker?
I crave the 125cc power. And I would love to embarass all the noisy Hollies from light to light when Im downtown.... But if I punch a whole in my AF16 block I will cry cry cry!!!
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
