1994 Elite...time for big bore? Help me out!
rboarderi
Post by rboarderi »
So I have a 1994 Elite S with 800 miles that I have converted to an SR. This is what I have done so far:
Ground out and de-restricted exhaust
Upjetted carb to SR 78 jet
New SR oil pump
New SR spilt oil pump cable
New Honda belt
Naraku variator (7g weights)
9:1 Gears
With this set up I am hitting around 44 on the flats and have topped out at 49.9 downhill. Even with the lighter weights and new variator I lost a bit of low end because of the gears. Is there anyway for me to get that low end back without a BBK, exhaust and carb?
If I go the BBK route I really would rather not modify my case. I would like to simply bolt on my new parts, tune the carb and ride. What BBK/exhaust/carb/ect combo would I want to look into purchasing that would not require modifying my case? Am I missing anything else I would need to purchase that I didn't list off? I'm not looking to have the fastest scooter around but I would like to be pretty fast off the line and maybe get into the low to mid 60's as well. Can anyone help?
ped
Re: 1994 Elite...time for big bore? Help me out!
Post by ped »
Hi rboarderi.
PM Red Eft Performance for a polini contesta BBK and bolt it on up jet to 91main jet that's it. power and speed. good luck.
bonesv
Post by bonesv »
rboarderi wrote:So I have a 1994 Elite S with 800 miles that I have converted to an SR. This is what I have done so far:
New SR oil pump
New Honda belt
9:1 Gears
First, yes, you can get the low end back somewhat. Use a 1000 rpm torque spring and get an asst. of the small clutch springs to fine tune to your weight for clutch "lock-up", maybe 1000, 1500, and 2000. It will depend on the clutch shoe "weights" that you have. The stock 1994 shoes are a bit heavier than the later years' shoes. Therefore, needing a heavier spring on the shoes. You will have to experiment to find your best fit. I keep extra set-up clutches for tuning as it's so much easier than trying to do it with just one. The threads are easy to strip also so be careful.
Second, you will need a bbk to get to anything near 60 mph. There is just not enough motor in the 49cc's to bring that speed. 9:1's is about it for the stock 49cc's to pull. Have fun and Happy Trails!
rboarderi
Post by rboarderi »
I think I'm going to go the contessa / 91 upjet route. Anyone have any other suggestions of anything else I might need or any comments on this set up?
sanjuro
Post by sanjuro »
I think the Corsa comes with a 82 main jet, but that's for the JDM carb.
...and, if you're going to spend the time to break-in a new kit, you might as well get the Corsa.
rboarderi
Post by rboarderi »
Installed a Malossi BBK last night and I am breaking it in right now. I am currently running a drilled 91 jet and premixing 30:1 in addition to the SR oil pump. I am going to run through 2-3 tanks with this oil mix for break in. After break in does anyone recommend a mix ratio or is it possible to just run with just my SR pump and SR cable. I would rather not just ditch my pump and cable as I just got them brand new a few months back. If I need extra oil in addition to the pump I would rather just dump it in the tank. Anyone have any suggestions?
Most modders and I run 32:1 premix, break-in as well as daily riding. More oil isn't necessarily better. You just need Enough. If you're really running 30:1 PLUS the pump, you've got yourself down below 20:1 total, which will require bigger jetting and still your engine may run hot. All the oil in the world won't save a hot engine.
rboarderi
Post by rboarderi »
I said that I was running the pump plus 30:1 just for break in. I will change that for my next tank though. So would you recommend something closer to 40:1 or 50:1 premix if I plan on keeping the SR pump?
Yes, I got that you intend to use the mix+pump for break-in. I'm saying that's a Bad Idea. Doesn't really help anything if the engine gets enough oil anyway, and can cause harm, sometimes catastrophic harm. Even during low-RPM break in. Don't ax how I know this... (Flash IV)
If you keep the SR Pump, your Shiny New Malossi could use 75:1 supplemental, at most. At 40 or even 50:1, we're back to WAY too much oil. Some modders run those ratios withOUT a pump. I prefer 32:1 because, well, I'm worried like you about being too low. At that ratio the smoke is acceptable and the plug doesn't foul. I'm on my 4th cylinder without a problem using it.
Between the extremes is usually found the right answer.
rboarderi
Post by rboarderi »
Thanks so much for the help so far everyone. Okay so now I'm running the SR pump as well as 75:1 in the tank. I have it idling fine but am having some troubles tuning the carb. I am running a drilled 91 jet in the stock carb. I am getting a little bit of stuttering when starting out from a stop and also some hesitation/bogging from time to time when I try to accelerate quickly when already rolling at 20-25mph. I am looking to regain a smooth acceleration that I had previously. Any help would be much appreciated!
Do I need to up jet, down jet, punch out second air box tab or just tune the carb better? The plug looks good, I have attached a picture. Also my temps have been good so far as well, the highest temp I have hit it right around 330.
Still rich methinks.
Red Eft Performance
Post by Red Eft Performance »
What is your mixture screw set at?
Red Eft Performance
View products click => Here
rboarderi
Post by rboarderi »
I have been playing around with the air/fuel screw all day but right now it is about 3 3/8 turns out.
Red Eft Performance
rboarderi wrote:I have been playing around with the air/fuel screw all day but right now it is about 3 3/8 turns out.
That should be too lean.
Whats it do if you do 1 turn out?
Keith
Red Eft Performance
rboarderi
Post by rboarderi »
I'll start with one turn out in the morning and let you know!
