LMH
Post by LMH »
LMH
Post by LMH »
LMH
Post by LMH »
deuce217
Re: 89 elite lx 72cc corsa swap
Post by deuce217 »
Thats classy! I am loving the racks! I bet wheelies are certain with those gears.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
LMH
Post by LMH »
LMH
Post by LMH »
LMH
Post by LMH »
A quick run when I thought the 130 was too fat, went back to 125. Hit 407 for a second at around 12k+ rpms. Can't just let off the throttle at those temps. It was running killer but lean as can be.
https://m.youtube.com/watch?v=UZKRyaAEQTQ
One of it during break in running.
https://m.youtube.com/watch?v=DYcFhf3EQ3Q
deuce217
Post by deuce217 »
LoveMyHonda wrote:A quick run when I thought the 130 was too fat, went back to 125. Hit 407 for a second at around 12k+ rpms. Can't just let off the throttle at those temps. It was running killer but lean as can be.
Those are some serious rpms, that pipe must be great at up top. How is the mid-range?
50mm BBK (tai)
V-8 pipe
LMH
Post by LMH »
LMH
Post by LMH »
Villyum
Post by Villyum »
dang this things a beast!
gperspective
Post by gperspective »
what size carb did you do?
graphite9 wrote:I think you should be jousting on this beast. It just makes sense. On side note, I do think people get really caught up in portwork, and boost port cutting/matching. Yes, it helps, But I've done several "slap it on and go" builds, and have always been extremely impressed. Did a dio with a contessa, carb/gears, stock exhaust, and the thing was really impressive.
Pocket Change . Scooter Club
Honda Spree . AF16E
Polini Corsa - Naraku Intake - Dellorto 21mm PHBG - Malossi E8 AirFilter - Malossi Variator 7g - ZX Trans - 9:1 - PG Short
ped
Post by ped »
Hi Mr. Love the pipe sounds good. and got to love the corsa. it can take some heat. :wink:
