Help With My Spree!
Help With My Spree!
Hello,
I've had my honda spree now for a while and need some help/advice to get it running as it once was!
Basically I took it to a mechanic about a year ago and he simply put a new starter in etc. It worked for a while after, but now it will NOT turn over. I've rebuilt and cleaned the carb and engine heads as well as replaced all the fuel lines. It could be the fuel pump because iam seeing NO gas go threw the lines when I start it over, but has does come out when i suck on one line.
Could someone please help me!
- Farfignugin
You're bike may be running the bowl out if the gas supply can't keep up with usage. You haven't mentioned the condition of the tank; the in-tank filter may be plugged. Drain the tank and remove the petcock to check the in-tank filter. If you can't remove it, clean the tank per procedure in tech docs.ben wrote:I;ve tried sucking on the vaccume line before (underneath the petcock) and only small amount of gas come out.
Could one of the reasons that its not starting is that the throttle it stuck?
For reference, the bowl should fill in about 10-15 seconds from empty when vacuum is applied.
You are filling the carb up with gas before trying to start the bike, right? Mine needs to be refilled if it's let set for more than 2 weeks.
Well i've already drained the gas tank and the gas wasnt in the best condition (it was stale and a brown color) so I then removed the petcock and checked if anything was clogged but it was ok. Could someone please take some pics of there carb/fuel lines/oil pump, so i can show where i think the problems lies!
Thanks!
Thanks!
