It ran fantastic and strong up until a week or so ago when I noticed sometimes it will stutter/bog down/lose power in certain situations. It happens when I start off from a standstill (at a stop light for example) above 1/4 throttle and until WOT.
I can usually prevent it from beginning to stutter after taking off by staying under 1/4 throttle or going WOT. If I back off on the throttle, I can get it to stop stuttering. If I quickly go WOT, I can get it to stop stuttering. But 1/4 to 3/4 throttle seems to cause these issues. It starts fine. It idles fine. It hasn't died on me (yet?). Seafoam in the tank did not help.
After searching around here, I plan to do the following to begin diagnosis:
- Inspect, replace spark plug, gap at 0.024"
- Inspect reeds. If damaged, replace
- Inspect float to make sure it's moving.
- Remove and clean pilot and main jets.
Thanks!
Seth
