My 94 Elite SR. daily driver. soon to be built.
hi forum. a photo at the local mc shop. with a dynojet.
1994 Elite SR
Polini BBK
9to1 gears
keli variator
metro rear wheel.
1994 Elite SR
Polini BBK
9to1 gears
keli variator
metro rear wheel.
- 20140820_142841[1].jpg (177.19 KiB) Viewed 13705 times
Re: My 94 Elite SR. daily driver. soon to be built.
picking up a few things.
- 20140820_182343[1].jpg (177.47 KiB) Viewed 13704 times
- 20140820_182412[1].jpg (170.51 KiB) Viewed 13704 times
ped wrote:picking up a few things.
- paulpauly7
Nice packing .
hi forum.
I notice the variator did not close all the way with the fly wheel. so I grind it down a little.
I don't remember where I got it from. maybe steve or fleabay? but it has a K in the inside.
- 20140825_173839[1].jpg (141.21 KiB) Viewed 13631 times
- 20140825_173806[1].jpg (150.65 KiB) Viewed 13631 times
- 20140825_171939[1].jpg (137.72 KiB) Viewed 13631 times
Now it close all the way.
the new belt looks like it may ride higher.
- 20140825_172730[1].jpg (126.98 KiB) Viewed 13631 times
- old belt
- 20140825_173420[1].jpg (127.74 KiB) Viewed 13631 times
- new belt
- 20140825_173534[1].jpg (138.62 KiB) Viewed 13631 times
I don't know who makes it? there is a K on the back can you see it?
- 20140825_173033[1].jpg (128.55 KiB) Viewed 13630 times
- 20140825_173645[1].jpg (176.52 KiB) Viewed 13630 times
Hi G9. I took off very little, it was more like dust.graphite9 wrote:I'd ditch that vari, if you had to grind on it. If it isn't 100% true, your asking for bearing, or crank spline damage. But that's just me.
I did find the package it's a keli variator. I hope didn't damage it?
- 20140826_005307[1].jpg (153.44 KiB) Viewed 13624 times
hi forum.
the 94 sr is going through a lot of oil.
I tied the pump open because it has a 70cc bbk.
should I leave it stock? it has the two wire throttle cable one for the carb, and one to the pump.
I think the sr pumps more oil?
thanks for any help.
- Red Eft Performance
Hello Friend
I usually plug the pump and premix with modified bikes.
If keeping the pump I would leave it tied open.
I think Mr. Wheelman figured out the ratios once on the pump and even when tied open its not a whole lot of oil for a modded bike.
Keith
Keith
Red Eft Performance
View products click => Here
Looks like its clean up limited to the variator counterbore. Does not appear it would impact running trueness.
thank you guys for all your help.
I was surprised that the Keli variator did not sit all the way.
thanks keith , I wasn"t 100 percent sure on the SR pump.
hi mousewheels. the cleanup was very lite and limited to fit exact.
thanks G9. eventually I will order a new one.
It was strange that i had to clean it out, on a keli part.
I appreciate everyone"s help thank you again.
hi forum.
I had 9g in the variator. I installed 7g rollers on the SR. the revs were too high. I'm going to try some Koso 8g.
- 20140830_012435[1].jpg (155.45 KiB) Viewed 13031 times
- paulpauly7
stock pipe and stock carb remember graphite
Hi G9, center spring is a red 1000k.graphite9 wrote:boy that seems heavy. I run 6.5-7g rollers. What rear center spring?
The SR has a polini BBK
9to1
keli variator
metro rear wheel
that's it for now.
