led blinker problem
- PorterGuy85
led blinker problem
Its a honda but not a scooter.Figured i'd post here.
Swapped from bulb type to led blinkers on my '85 xl350r.
The problem:
If I push the indicator switch to Left or Right I get all 4 blinkers to come ÒÇèÒÇèonÒÇïÒÇï
No blink, no flicker just on.
I figured i'd have them hyperblink. Put in a new relay since the oem was bad. New one does same thing. Bench tested it with a spare trailer light
Here's some vids. Thanks guys
Led blinker swap '85 honda xl350: http://youtu.be/M9CuilC5rNE
Flasher relay testing: http://youtu.be/VEwiX-4inKg
The problem:
Pineapplegti
Re: led blinker problem
probably need a resistor..
- PorterGuy85
I figured I'd need something, but what has me puzzled is when L or R is selected why do all 4 come on? They're 2 separate circuits. I could see both left or both right, but all 4? And they should at least blink fast, then a resistor would slow it down.
Hi PG. your LED'S do not have enough watts to trigger the flasher. you need a led flasher relay.
do a test, put back one bulb in each side, and one led on each sides give it a try. the old bulb will put a load on the flasher and should blink.
if not working connect all the bulb including the led. give it a try. the lights should blink.
check flebay for a led flasher relay. one that you can adjust. hope this helps.
- PorterGuy85
Awesome, thanks. I will try it.
- patthesoundguy
I bought led flashers for scooters from China. They cost around 2.50$ free shipping. DX.com they flash with any amount of load
it even has the rubber mount and is the same shape and size as the OEM honda scooter relay http://www.dx.com/p/cyt-plastic-electri ... Am0ELdyfng
- PorterGuy85
I picked up an electronic relay earlier. It's 3 prong. My thermal had 2. This is ground, 12v., load. Do I have to ground it now. Or just use the same 2. Load and 12v.
Hmm. I think you need the two prong for motorcycle. I never tried the 3 prong on a bike.
- PorterGuy85
Well I have some closer good news, with the electronic flasher installed. I have all ÒÇèÒÇè4ÒÇïÒÇï flash at a good normal pace. Like hazard lights in a car. Whether I select L or R.
- patthesoundguy
Sounds like a short somewhere. Or some wires in nthe wrong places. You may have to follow all of the wire in the harness and check to make sure all connectors are going to the right plugs
- PorterGuy85
Yes, I concur. Probably wires crossed. I'll check later. Thanks for all the help.
- PorterGuy85
Traced all wires and compared to a wiring diagram for the bike, all checks out. Last place i've checked is the indicator bulb/wiring. The bulb doesn't come on.Since it is for L & R, both wires leading to the blinkers also come to this point and emit the single "bulb". I either have a short there or the bulb burnt/causing lines to touch or because its a bulb & not an led. But I still have the 4 way hazard light effect. Relay seems to be fine.
- patthesoundguy
Boy I think you have really gotten to the spot of the issue
- PorterGuy85
- PorterGuy85
Problem solved. As I suspected. Pulled the instrument panel blinker indicator bulb and Bingo!!
Blinkers work as they should. I dont really need the indicator, since I can see the lights themselves.
Thanks again for all the help & input.
