2001 honda elite
curtis966
Re: 2001 honda elite
Post by curtis966 »
Because they are wider, tubeless, and a bolt on upgrade. They run about $100 a set over a disc set up which will be $200 for rims at the cheapest plus a $150-250 set of forks and another $200-300 for the caliper break levers and rotor. Not to mention the fab work for the tree to fit the plastics. Can be done for a little cheaper if you find a dio zx front end to use but good luck there :) talk to graphite9 he'll let you know how much work it takes. Unless your planning on doing 70mph on the regular the drums are pretty good. Just get your self a set of slotted brake pads for the front and back they do wonders over the stockers. Or if you've got the cash go disc they do look bad *!
bonesv
Post by bonesv »
scootfast wrote:Where are you in fla. Coming down in January. New Smyrna area
Hey Jim, I'm in Key West if you want to look me up. Seriously, the wheels in the pics are metro wheels as curtis mentions. The aluminum wheels are rare and expensive. They scream "steal me" when you see them.
paulpauly7
Post by paulpauly7 »
i love my disk brake its from a AF28 diozx and same as graphite if i wanted to flip the bike i could with a squeeze of the brake lever .Befor i had the disk i totally cooked the front brake warped the drum burnt off the high temp powder coat with smoke pouring off the brake lol.
ped
Post by ped »
scootfast wrote:[*]
hi scootfast. Beautiful color what's it called?
scootfast
Post by scootfast »
It's called tangerine kandy. Silver base with top color and clear. It's from house of colors.
scootfast
Post by scootfast »
scootfast wrote:It's called tangerine kandy. Silver base with top color and clear. It's from house of colors.
Where are in the northeast?
scootfast
Post by scootfast »
scootfast wrote:[*]
