I pulled the spark plug out last night and the previous owner was using the NGK BPR4HS(cold climate) instead of the NGK BPR6HS(standard) plug. I live in Chicago and will only ride the scooter in the summer. I need to buy a new spark plug but not sure if there's a huge difference in using the BPR4HS vs BPR6HS? Any info is appreciate.
Thanks
spark plug question
Re: spark plug question
I'd go with the correct one, unless you're always riding really Slow.
Thank you, Wheelman
