Quieter Pipe For my 125cc Stroker ???
Hppowdercoatings
Post by Hppowdercoatings »
Got my 87 Elite with 125cc Stroker running like a Raped Ape but it's Really loud with the V8 pipe.
Any Recommendations on a Quieter but good flowing Pipe ?
Pic of Current V8 pipe..
Re: Quieter Pipe For my 125cc Stroker ???
I've got an RDO.
It's like the pg long, but for a stroker.
it's still pretty d*** loud though.
Hppowdercoatings
graphite9 wrote:thats not a v8, and it looks like thats not a 120cc pipe..I had the big scorpion, and it was a screamer. I don't think there is any way around the noise.
Well it came with the Engine when I bought it, Says V8 on it, was blue before I powder coated it black.
How do I tell if it's a 120cc Pipe ?
I don't think the Neighbors like it when I ride by with it screaming at 9500rpm..lol
Johnniespeed
Post by Johnniespeed »
Cut the u-pipe off the convergence cone of the expansion chamber and weld that hole shut, using a small hole saw on the belly open a spot for your tail pipe and weld it into the belly. The performance will not change but the noise will greatly be reduced.
You can Google the subject of belly exit expansion chambers to get more technical information.
My pipe used to look like yours, ear splitting noise, changed to belly exit and noise greatly reduced with no performance change.
You can see the photo, to get the idea.
Dio pipe 010.JPG (142.74 KiB) Viewed 17884 times
Dio pipe 009.JPG (146.11 KiB) Viewed 17884 times
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
paulpauly7
Post by paulpauly7 »
MLM mostly make side bleed pipes for this reason less noise .
Hppowdercoatings
Johnniespeed wrote:Cut the u-pipe off the convergence cone of the expansion chamber and weld that hole shut, using a small hole saw on the belly open a spot for your tail pipe and weld it into the belly. The performance will not change but the noise will greatly be reduced.
Thanks for the info "Johnniespeed". After a little Research I figured what the Heck and Give it a Shot and Make my Pipe into a side Bleed Pipe.. Guess what . It worked Better then I hoped it Would. After a couple rides around the Block I Noticed NO changed in the Bikes Performance. But I would say it DID Quiet it down 50-60%... :rock:
Here's a few pic of Exhaus after Mods. I still plan to remove it again so I can Sandblast and Ceramic coat it..
bigreed
Post by bigreed »
Are all of the sweet side exit (like johnniespeed) with the header going right instead of down custom? I've seen a few homemade on random drag race builds
The pipes ive used so far just hang to low for my combination of heavy weight 250lbs, crappie roads and the need to hit every apex.
Dio pipe 004_20140924_154531.jpg (38.88 KiB) Viewed 17837 times
99 Elite 50S GPS coming soon 9520rpm
|Airsal|Scorpion|Arreche|Uni|outerwear|ncy|8.4|TrailTech
87 elite 50 S :-D
bigreed
Post by bigreed »
Found another cool example
I think something like that would cure my header smash anxiety
Might just have to find a welder to hack my old next rs into a belly bleed side pipe for the 70cc
87 elite 50 S :-D
paulpauly7
there are a few pipe ls like these on yahoo auctions japan for AF18 and variated AF05E .
Hppowdercoatings
Took Pipe off today and Coated it..
808EERPS48
Post by 808EERPS48 »
you could run a V8 hurricane and box it up itll take way some power but it will the quitest route
84 Spree dio ready
Youtube me: Go RYAN Pro
True 72cc
70+/F/72
Reppin it for the 2+ class
Eastsydah Rydah Productions
#Handodat
bigreed
Post by bigreed »
Hppowdercoatings wrote:Took Pipe off today and Coated it..
Looks awesome!
87 elite 50 S :-D
ped
Post by ped »
Hi bigoted. very nice. and I like the look.
question I wonder if you were to face the muffler forward would it put less stress on the mounting bracket? it would change the look.
bigreed
Post by bigreed »
paulpauly7 wrote:there are a few pipe ls like these on yahoo auctions japan for AF18 and variated AF05E .
Cant find any tried chamber, muffler, pipe, maybe just not at the moment, what keyword should i try. AF18 "keyword?"
87 elite 50 S :-D
paulpauly7
af27 or af28 or dio
