1st step on my new project
- AIO MotorSportS
- Goped
anybody recommend good epoxy with high resistence to heat,crack,chip,bend,etc for use to fill my oil pump hole?
- CAM00937.jpg (179.49 KiB) Viewed 11538 times
Pineapplegti
Re: 1st step on my new proyect
First use a oil pump plug..then you can epoxy or make a bracket to secure it there..You need to take the space up that the oil pump took up.
- AIO MotorSportS
- Goped
got it,thanks,but I looking for something else,if you see the aluminum bushing I make...
- AIO MotorSportS
- Goped
that the way I hold the oil plug now
- fotos del telefono1 050.jpg (93.84 KiB) Viewed 11529 times
- AIO MotorSportS
- Goped
thanks red eft performance
thanks redeft performance,the crank delivered monday,hope can install it with the malossi bearings soon
- CAM01172.jpg (132.26 KiB) Viewed 11472 times
- CAM01169.jpg (152.67 KiB) Viewed 11472 times
hi AMS. you may have to make a custom plug?
steel epoxy may brake or fragment inside the motor?
not good with the new malossi crank.
I like your thinking tho. :
dabinonahonda
nice cant wait to see more
1988 hd sportster 883 evo
1983 hd sportster 1000 roadster
2001 Honda elite s
2001 Honda elite s
- AIO MotorSportS
- Goped
[/quote]
thanks
thanks
- AIO MotorSportS
- Goped
graphite9 wrote:Get an oil pump plug, and cut the end off if need be. Don't use any type of epoxy down there, that's a bad idea. Also, maybe sure your using correct tools to install that crank. Don't hammer, pound, or press the cases together. It's too nice of a crank to damage. Do it right.
don't worry,like "all state insurance" all parts are in good hands,
- AIO MotorSportS
- Goped
hi dabi,I'm spend just 20/30 min a week on this hobby,so this way take me a little long to update the proyectdabinonahonda wrote:nice cant wait to see more
Johnniespeed
Link to oil pump delete. http://hondaspree.net/wiki/index.php5?t ... Pump_Plugs
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
- AIO MotorSportS
- Goped
Johnniespeed wrote:Link to oil pump delete. http://hondaspree.net/wiki/index.php5?t ... Pump_Plugs
hi,good link thanks,but still dosnt work for me,
on other word I want the mix run freely on the crank case without any detours and + get more bottom comp
Johnniespeed
I am also a KX500 rider, and the race guys stuff the crankcase ( to reduce volume) with Devcon. Apparently it moves peak torque up the RPM scale. They surround the crank area and machine it out, I forgot what clearance they use, but it's only a few thousandths to allow for expansion and vibration. The trail riders do the opposite and add reed block spacers to increase crankcase volume and lower peak torque rpm.
I have never used Devcon, but it has been around for years.
- AIO MotorSportS
- Goped
really good info,thanksJohnniespeed wrote:I am also a KX500 rider, and the race guys stuff the crankcase ( to reduce volume) with Devcon. Apparently it moves peak torque up the RPM scale. They surround the crank area and machine it out, I forgot what clearance they use, but it's only a few thousandths to allow for expansion and vibration. The trail riders do the opposite and add reed block spacers to increase crankcase volume and lower peak torque rpm.
- AIO MotorSportS
- Goped
I spend a couple hours on my project this week,case ready to fill it up and intake ready.
- CAM01260.jpg (120.18 KiB) Viewed 11277 times
- CAM01244.jpg (81.96 KiB) Viewed 11277 times
- CAM01241.jpg (82.01 KiB) Viewed 11277 times
