1st step on my new project
AIO MotorSportS
Post by AIO MotorSportS »
anybody recommend good epoxy with high resistence to heat,crack,chip,bend,etc for use to fill my oil pump hole?
Pineapplegti
Re: 1st step on my new proyect
Post by Pineapplegti »
First use a oil pump plug..then you can epoxy or make a bracket to secure it there..You need to take the space up that the oil pump took up.
AIO MotorSportS
got it,thanks,but I looking for something else,if you see the aluminum bushing I make...
AIO MotorSportS
that the way I hold the oil plug now
fotos del telefono1 050.jpg (93.84 KiB) Viewed 11527 times
AIO MotorSportS
thanks red eft performance
thanks redeft performance,the crank delivered monday,hope can install it with the malossi bearings soon
ped
Post by ped »
hi AMS. you may have to make a custom plug? :nerd:
steel epoxy may brake or fragment inside the motor? :nervous:
not good with the new malossi crank.
I like your thinking tho. : :wink:
dabinonahonda
Post by dabinonahonda »
nice cant wait to see more
1988 hd sportster 883 evo
1983 hd sportster 1000 roadster
2001 Honda elite s
AIO MotorSportS
I like your thinking tho. : :wink:[/quote]
thanks :thumbwink:
AIO MotorSportS
graphite9 wrote:Get an oil pump plug, and cut the end off if need be. Don't use any type of epoxy down there, that's a bad idea. Also, maybe sure your using correct tools to install that crank. Don't hammer, pound, or press the cases together. It's too nice of a crank to damage. Do it right.
don't worry,like "all state insurance" all parts are in good hands, :mrgreen:
AIO MotorSportS
dabinonahonda wrote:nice cant wait to see more
hi dabi,I'm spend just 20/30 min a week on this hobby,so this way take me a little long to update the proyect :hi:
Johnniespeed
Post by Johnniespeed »
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
AIO MotorSportS
Johnniespeed wrote:Link to oil pump delete. http://hondaspree.net/wiki/index.php5?t ... Pump_Plugs
hi,good link thanks,but still dosnt work for me,
on other word I want the mix run freely on the crank case without any detours and + get more bottom comp
:smile:
Johnniespeed
I am also a KX500 rider, and the race guys stuff the crankcase ( to reduce volume) with Devcon. Apparently it moves peak torque up the RPM scale. They surround the crank area and machine it out, I forgot what clearance they use, but it's only a few thousandths to allow for expansion and vibration. The trail riders do the opposite and add reed block spacers to increase crankcase volume and lower peak torque rpm.
I have never used Devcon, but it has been around for years.
AIO MotorSportS
Johnniespeed wrote:I am also a KX500 rider, and the race guys stuff the crankcase ( to reduce volume) with Devcon. Apparently it moves peak torque up the RPM scale. They surround the crank area and machine it out, I forgot what clearance they use, but it's only a few thousandths to allow for expansion and vibration. The trail riders do the opposite and add reed block spacers to increase crankcase volume and lower peak torque rpm.
really good info,thanks :bowrofl:
AIO MotorSportS
I spend a couple hours on my project this week,case ready to fill it up and intake ready.
