oko question
patthesoundguy
oko question
Post by patthesoundguy »
Are there any different atomizers for the oko? Could it be possible I have an oko on my two stoke that could be setup for four stroke?
patthesoundguy
Re: oko question
I thought so. I knew they had to just never seen them readily out there. Seen lots for delorto. My dio spree is kind of hit and miss sometimes. I think it has something to do with the carb. I need to break down and get the new polini carb. The 28mm oko on it is of unknown origin, it came on the motor.
patthesoundguy
Re: oko question
graphite9 wrote:28mm is just wasting fuel anyways
Yup that it does. Its not bad when everything works correctly but when it's not working the way it should it uses way too much fuel.
