What does it cost to rebuild an AF16E motor?
CNI Dawg
Post by CNI Dawg »
My oil pump failed and the motor seized up in my Elite 50SR
I fear a full engine rebuild is in order
Can you guys give me an idea what it will cost to rebuild it - including rod bearing replacement?
Thanks
CNI Dawg
61Aand Still Having Fun !
Keeping the Dream Alive ! :)
01 Elite 50SR
CMRA #77 MCE, '03 CBR600RR - Dark Horse Racing
patthesoundguy
Re: What does it cost to rebuild an AF16E motor?
Post by patthesoundguy »
It all depends on how much you want to spend ;-) there are so many different kits for that motor its mind blowing. From stock to ridiculous speed. It all comes down to what you need and want. It may be a good time to upgrade the bore to a bigger bore. Quick bolt on and re jet and you'd be on your way. I bet graphite9 has what you need to get up and running again. And he will have it at a great price too. You may find a good quality big bore kit that might be of better quality than the stock one was for a better price. Be sure to get an oil pump plug while your ordering parts. Then run premix and forget the pump.
CNI Dawg
Post by CNI Dawg »
Thanks !
Good idea about the oil pump - that is what got me in trouble to begin with !!
01 Elite 50SR
scootfast
Post by scootfast »
How much do you want to spend. That's what it cost. And what do you want or expect?
CNI Dawg
Post by CNI Dawg »
Thank you graphite9 !!
I am adding the rebuild to my winter project list.
1st thing is to get the cylinder off & see what damage there is.
THanks for the tips for checking.
I, like you, am thinking of a performance rebuild ! :)
01 Elite 50SR
