I scooped up an 04 2t zuma the other day and have come to a hault. I've never had a billow of smoke roll out of the carb intake. Carb is clean and tank is clean with fresh premix. The Autolube is hooked up for now until I verify the Autolube is working. I have done this with hondas but could this be the reason why my zuma isn't starting? I got spark and compression does not appear to be the issue. Any help is greatly appreciated.
Plug seems to continually get wet.
04 zuma smokin out the intake
Ruckenstein
Re: 04 zuma smokin out the intake
Can't be much else besides reeds, but is it vapor or really Smoke?
Ruckenstein
If vapor, Graphie is correct. Fuel mix goes in, gets pushed back out through a gap in the reeds.
- Mini_Stroker305
- Goped
Wheelman-111 wrote:Greetings:
Couldn't agree more definitely a reed issue you have there my friend.
96 Yamaha Jog Next Zone CY50
72cc Polini Evo 2
Ruima 41.4 Teflon ministroke
Yasuni C16
24mm Polini pwk
Malossi 8:1 Primary Gears
Malossi VL14 Reeds
Polini 360 Mani
Jaingwayne transmission
Michelin S1 tires 90/90/10
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
