1st step on my new project
AIO MotorSportS
Re: 1st step on my new proyect
Post by AIO MotorSportS »
pics
LMH
Post by LMH »
Nice clean up, the ct can use a lot of porting on the down turn.
paulpauly7
Post by paulpauly7 »
Match up that little triangle in the port with the other side .Is this a stroker ? Them some big ports .
AIO MotorSportS
LoveMyHonda wrote:Nice clean up, the ct can use a lot of porting on the down turn.
Yes Sir :thumbsup:
AIO MotorSportS
paulpauly7 wrote:Match up that little triangle in the port with the other side .Is this a stroker ? Them some big ports .
Match where?pics please
No
Malossi mhr high speed bearings
AIO crankcase job
Im just starting on my AF16 project :thumbwink:
paulpauly7
top left in your first pic and bottom right in your second pic .where the base gasket sits the looking down into the cases the port windows have sharp corners stator side is open intake side is half blocked.
AIO MotorSportS
paulpauly7 wrote:top left in your first pic and bottom right in your second pic .where the base gasket sits the looking down into the cases the port windows have sharp corners stator side is open intake side is half blocked.
Got it,thanks, im going to match all when i get the cylinder kit and started to work on it. :thumbwink:
curtis966
Post by curtis966 »
What cylinder kit do you plan on running? Your port job is looking top notch very clean ct. But like Pauly said make sure you smooth out that little triangle will cause a lot of blockage for air and fuel movement.
AIO MotorSportS
curtis966 wrote:What cylinder kit do you plan on running? Your port job is looking top notch very clean ct. But like Pauly said make sure you smooth out that little triangle will cause a lot of blockage for air and fuel movement.
Got it,thanks,like i said im just started
When i get the cylinder kit im going to see what i get and what i
have to do :thumbwink:
AIO MotorSportS
working on the crankcase,one step less :ndance:
paulpauly7
What is that stuff?
chamisataza
Post by chamisataza »
is that J-B weld original?
AIO MotorSportS
chamisataza wrote:is that J-B weld original?
Is a two parts marine epoxy + high temp fiber glass fabric
used for 2 stroke engine on
stand up jetski
Jbweld dont work with gas n oil
AIO MotorSportS
graphite9 wrote:wow, you put time into that. Kudos.
No much ,just few min a week,i don't have the time to spend on this hobby like a want to. :ndance:
ped
Post by ped »
Hi AIO. Do you have a name for that stuff?
what are you building? 72cc? :shock:
