So I was enquiring about another DJ1 scooter for sale and the guy says it has a A-AF12 engine in it....
Is that like the predecessor to the AF18?
Wondering if its worth anything
Honda DJ1 with a AF12 engine
-1990 Honda DJ1-RR- a work in progress....
-1988-ish? Honda DJ1-R
-1980 Yamaha V50
-1980 Yamaha V50
Re: Honda DJ1 with a AF12 engine
I looked it up. It is the af05 engine code. The DJ1-RR is the af18.bootz1 wrote:So I was enquiring about another DJ1 scooter for sale and the guy says it has a A-AF12 engine in it....
- paulpauly7
dj1 is af05e dj1 r is af05e but has larger transfer ports its a 6 port in the barrel,factory chamber pipe,larger reeds,bigger jets and 10:1 ratio.unfortunalty the malossi bbk wont fit the dj1r af05e motor but there is a 44.5mm kitico piston for them.The dj1rr is the first known af18 motor even befor the dio these are small shaft cranks .
Sweet cheers for the heads up bones and Pauly
-1980 Yamaha V50
-1980 Yamaha V50
Af12 is like a model number for the body
