Can you run a 72cc polini corsa on a small crank af18e?
veedubh20
Re: Can you run a 72cc polini corsa on a small crank af18e?
Post by veedubh20 »
DirtyE wrote:digging up the past here, but an af18 will work in a af16 crankcase? It will just require 87 bearings/ seals, and a malossi af18 vario?
to your question.
yes can on the left af16 case and right af18 case with mag and stator should work.. with s/zx boss. not with 87 left small seal, 87 driven pulley/ drive face.
