cruzingratiot
Post by cruzingratiot »
what pulley/ramp? polini
what is crusing temps/rpm at 50mph with that tune? 300-310 about 9,600 ish
how much do you weigh? 160 lbs
Donate Life
http://www.donatelife.net/
Thank You
cruzingratiot
after 5+ months the rear rims arrived
pre ordered from jiangwayne.com july 24
received front rims sept twenty something
jiangwayne had a problem with rears wrong spline count
that is why it took so long to get rears
when I pre ordered and saved $ 21.00 on each rim 84.00 total
and a break on shipping so it was worth the wait to me
Part numbers front has 12 mm axle
RPM 10"x2.15J Front Wheel (Dio TDM, Black) - 44650-GW0-R02B
RPM 10"x2.15J Rear Wheel (Dio, Black) - 42601-GW0-R02B
was going to use the rims I had but like the looks of the straight spokes better
probably going to sell since i bought 2 sets of the other ones
Donate Life
Thank You
curtis966
Post by curtis966 »
I might be intrested in the 6 spoke set if you sell em.
LMH
Post by LMH »
If Curtis doesn't buy them I will. They look sweet!
cruzingratiot
steering stem 14.75 inch from bottom of race to top
2.0 inch of full thread 2.25 inch counting partial threads
will edit later for thread pitch diameter and bearing race diameter ect
the bottom part of pic is what the stem looks like after you cut the forks off
EDIT 12-26-2014
Dio style with 12mm axel / Ruckus triple tree comparison
so if you use a ruckus triple tree the spacers would need to be 13mm wider on each side
to keep the rim centered
45.5mm 1.791 inch total on speedometer side
25mm .984 inch on other side
dio style with 12mm axel triple tree stock spacers
32.5mm 1.2795 inch total on speedometer side
12mm.472 inch on other side
I would assume the 10mm axel forks have identical spacers
Last edited by cruzingratiot on Fri Dec 26, 2014 12:56 pm, edited 3 times in total.
Donate Life
Thank You
LMH
Post by LMH »
Making a stem?
cruzingratiot
thinking about making the stem instead of welding 2 together
or
seeing if I can save this one and mount / weld it into a dio or ruckus tree
the tree that came with front I bought didn't like how it was welded
keeping my options open
Donate Life
Thank You
cruzingratiot
so if you mill / grind the weld off the bottom of the ruckus tree
and push the stem out
the hold diameter is the same size as the elite stem
so if you can get the weld off the elite stem
push it into the ruckus stem
re weld the bottom (and maybe drill and a plug weld on side)
you would be good to go
Donate Life
Thank You
AIO MotorSportS
Post by AIO MotorSportS »
Nice work,could be look like my one when you finish the front set up
TinyElvis
Post by TinyElvis »
:thumbsup:
cruzingratiot wrote:so if you mill / grind the weld off the bottom of the ruckus tree
Honda DIO 3 ZX Live, Malossi, WindJammah!
cruzingratiot
graphite9 wrote:Why don't you cut the ruck tree, and weld the elite tree upper to it? Sleeve it, its a cake walk. You don't want to be welding and messing with the attachmen points, unless your really skilled with metal fab.
I was a machinist for 20 years
and have fabricated many things
and want to show different ways to do things
this isn't my first sterring stem project
and i already have a elite welded stem in my possestion
i just want a one piece stem
here is my first fork swap
1984 Kawasaki 750 Turbo
with 2000 Kawasaki zrx 1100 forks and custom stem
Suzuki Hayabusa swingarm with a Kawasaki rim ,r6 handlebars
and many other mods that i performed
which is still in my possession
Donate Life
Thank You
willburr76
Post by willburr76 »
What are the 6 spoke wheels from. I'm curious as to what wheel choices I'll have in the future. Thanks
Pineapplegti
Post by Pineapplegti »
Finally got around to checking your thread out.. Looks like g9 will be getting more of money. I'm still sub 70s with a corsa ,grrr. Nice work
That ZX 750 Turbo is a true gem.
The boxes for the rims say "For Best Rider Only". Gotta love those Chinese translations. :)
cruzingratiot
Wheelman-111 wrote:Greetings:
i was waiting for someone to see and comment on that "For Best Rider Only".
Thank you i have alot of time in it
willburr76 wrote:What are the 6 spoke wheels from. I'm curious as to what wheel choices I'll have in the future. Thanks
the 6 spoke are honda dio style
or aftermarket
KN Planning MODEL : WH17
http://japan.webike.net/products/21357113.html
Donate Life
Thank You
