Tranny & Final Drive Fluid Change Frequencies
Johnniespeed
Re: Tranny & Final Drive Fluid Change Frequencies
Post by Johnniespeed »
Does your city have a local Scooter club ? Mine does, we have organized rides and outings.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
stevemarx
Post by stevemarx »
Guys,
First, happy holidays to all!
I am back with a couple of questions, since I have finally made the time to perform some maintenance on our '86 Spree. Your help would be very much appreciated. Here goes:
1. The manual says '85 Spree's have 4 amp hour electrical systems and '86 models have 3 amp hour systems. We have an '86 (per the title) but the replacement battery is a 4 amp hour and not a 3. Should I be concerned? It did die after sitting for a while and I need to buy a trickle charger.
2. I cleaned the oil strainer (actually not dirty at all) and now have to bleed the oil lines. I am somewhat competent and don't want to mess it up. Any tips beyond what's in the service manual? Is it really necessary to bleed the lines?
3. Final drive clarification - I see the circled drain plug (pic below) and can drain it. Do I have to turn the scooter on its side to refill the 3 ounces? Will it flow out as I pour it in if I don't put it on its side?
Thanks again. Really appreciate all the help.
Steve
DirtyE
Post by DirtyE »
I pulled my cover the other night and the oil that came out of there was disgusting. Mind you I have a 98 and its probably never been changed.
On other model scooters Ive used gasket maker. I was actually planning on using the same stuff for this gearbox as well. I forget the color RTV.
98 Elite
4 strokes are for cars
The thickness of the gasket is calculated into the end-play of the various shafts. If you use goo, the cover will get too close to the gearcase and bind the countershaft. Honda and the aftermarket (Partzilla) still stock the gaskets for about $7. Cut paper if you must, but I recommend you don't use gasket-maker liquid.
curtis966
Post by curtis966 »
I agree with Wheelman the stock gasket is your best bet. With aftermarket gears sometimes the shims need to be changed for it to fit correctly.
