Hey gents
Has anyone ever adapted a disc onto the stock fork assembly. Is it possible to attach a bracket to the pivoting arm?
I like the stock fork look, it fits perfectly with my current build, the stopping power is just not enough.
Disc possibilities on oem forks
88 SA 50- Af16e swap
87 Se 50 - 01 Af16E build
Re: Disc possibilities on oem forks
No it will bind up or hit the caliper if it's a elite s style front fork. If it's telescopic fork then you can probably get it to work. Just upgrade the brake shoes to ebc or any aftermarket racing brake shoes or just do a full disc swap front end. Enless the person welding the bracket is a very skilled welder, I wouldn't trust welding a caliper bracket on a fork that wasn't mentioned to have one. If it fails you risk getting really hurt or even death. If your going to do it, do it the right way.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
