Anybody have good luck getting a Spree clutch relined and if so where?
Thanks
Spree Clutch re-lined
Re: Spree Clutch re-lined
Clutch weight sets are available from Partzilla (about $50). I've done a few and are fairly easy but be CAREFUL when taking off the large nut that holds everything together. Sometimes you can find good used clutches on ebay that are cheaper. Good luck.
They don't have them. I called and there no longer made
- swimmingfree
MopedMark is some one you cood try on here and cant rember the other guy... i think its martynkim ???
Mopedmark does not sell parts anymore
Bump, Anybody have good luck getting one relined? And if yes where?
