The scooter in question is '87 Aero 50 AF05E.
The PIPE in question is the NEW ScooterSwapShop pipe.
The Main Jet will need increasing.
What is the OEM spec of the Main Jet ??
(too cheap to download manual...eats up my bytes)
How much bigger Main Jet is normal ??
Am I Limited to a Pilot Jet that cannot be changed ??
Thanks in advance...
RideRed <Helix><(2)Gyro S><Rebel><CB100><Urban Express><Aero 50> "Live Large - Ride Small"
Two virgin AF05s I've dismantled both had 82s. One was a Japanese-spec DJ-1. We know there's a way to enlarge the Pilot, found on your Golden carb..., but I don't recall anyone posting outcomes. If I were running an 05, I'd spring for an Arreche/Amal carb for Honda and open up more possibilities. It runs stock intake, airbox, cable and bystarter.
In treatlands.tv selection of carbs, I found no Arreche, but did see some Amals.
I suppose i should do some testing before rushing into more cash expenditure.
motormike wrote:In treatlands.tv selection of carbs, I found no Arreche, but did see some Amals.
Exactly...
thanks for getting me there so quickly bonesv.
With the addition of this Aero to the stable,
I'm having some fun putting together a ride for the drag-strip. >........................................................................................................................
dun rite wrote:what size arreche you thinking about MM.
As I see it dun rite, I may not need to change carbs with the stock bore.
If I did a bbk, I suppose I would pick between the 16 & 17 1/2...
What is the stock intake I.D. ?...gone to check Wiki...
