My 1995 Honda Elite SR modded!
Xxbeejay45xx
Post by Xxbeejay45xx »
It's been a few years since I started looking for a Honda Elite moped. Grew up on Hawaiian islands, so I was used to seeing these things go really fast. So then I found this site and started reading and more reading and then I pick up a one for $300. Bought parts off eBay to start my adventure. Here are some photos as I go along and have time to post more, enjoy.
ImageThis is how it looked when I first got it.
First thing I did was strip everything down, and stretch the scoot and lower it with a cheap disc brake setup.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
Xxbeejay45xx
Re: My 1995 Honda Elite SR modded!
Next was to cut off the exhaust hangers and shave down the cases to fit the fatty rear on.Image
ImageThen came the extended motor mount.
Image So now its time to mock up everything in the rear.Image
Now that the rear has been lined up, it's time for the front end to get disc up!
Lots of cutting and welding and more cutting of plastics.
Imagebought a none running Jon way scooter and used the front end.Image
Time to cut these up. Image
ImageSee how much longer and thicker the Chinese scooter has, it won't fit our elites.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
Here it is after all the hard work.
Now the headset, I used the same headset off of the Jon Way I bought.
Now its time to strip down the whole thing and make it look pretty.
I sanded and painted the frame metallic blue.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Post by swimmingfree »
nice job there guy ... so what have you done to the motor???
Xxbeejay45xx
Well, I started out with the cheap eBay kit that had everything, it was a good starter kit as with most newbies, I toasted the bore after ther second week.
And a fabrizi pipe from Big Red. Thanks!
Sanded and polished the front wheel that came with the donor front end, found similar rear fatty wheel on eBay and I like the white wall tire look so bought those too. FYI 3.5 up front will be very tight and it won't fit on the rear, will rub engine case)
Cleaned and polish engine and then 9.1 gears on.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
Here is it all together before painting body panels.
Sitting back enjoying the work and progress.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
Painting time!!
Gonna try to carbon fiber the dash with the vapor unit inside.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
As of the latest photos, I had a 90cc Taiwan bore which isn't exactly 90cc, a pwk 28 carb, chrome ct mannifold, wrong size K&N airfter. Prodigy variator, aftermarket belt, prodigy clutch, clutch bell, yellow center spring. Fabrizi pipe.
Then came the mighty Polini Corsa from Graphite9, thanks.
Polished and clean block.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
ped
Post by ped »
Hi beejay45. nice thread, great build. The Motor looks great. :thumbwink:
*what happened that the Taiwan cylinder seized?
Xxbeejay45xx
ped wrote:Hi beejay45. nice thread, great build. The Motor looks great. :thumbwink:
Ohh I didn't break it in like how everyone did, me and my father inlaw slapped everything together and rode it around the block. It was good until it kept seizing after 15mins of riding and then eventually stop running, new rings and hone couldn't fix what we destroyed lolz.
So in the plastic bag it went.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
So on to the dash I was trying to whip up.
Bondo then carbon fiber
Finished product.....
And some hid headlights to go with
Finish with what I had in mind but wasn't digging it.... :imo:
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
Also remolded the rear fender and carbon fiber that too.
I was in the mood for carbon fiber so I tried to do a under cowling also...... But need more practice! Lolz
Once it got hard I took it off and laid a really good coat of fiberglass to it.
I swam it at the bottom so no one can see it. It looks ok, everything from scratch and lots of hours so I'm keeping it on lolz. I also redid the fabrizi pipe silencer. Shorten it and carbon fibered it too lolz.
Done with and now to wrapping it.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
birdman
Post by birdman »
Nice looking bike!!
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
Xxbeejay45xx
Wrapped it also
Couldn't get my hands on a Japan rear rack song made one myself out of the old rack, and it's free check it out.
This two cuts are to bend the rack downward.
And here is the finished product.
Looking good, running great and just needed to fine tune transmission then the unthinkable happened let a friend ride it and whamp!! Into a parked car!!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
REBUILD!!! More to come!!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
