I did a compression test and it turns out it is at 90 psi. This explains why it will not go fast at all, I thought my tester was bad and tried, jets, it runs best with a 100 main right now, forgot to check the slow jet. I revs decent on the stand but under load, no Huevos.
I decided to look inside because the old lady I bought it from knew literally nothing about it other than her husband bought it and never drove it. I feared the cast cylinder had rusted over the years from never being used
I was wrong
Its has a 22mm mikuni carb runs like a turd...
I took it apart to see whats up. Nothing weird looking, but the ring is definitely not seating. When I reassembled it I used plenty of 2t oil and it seemed to have helped the compression for about half of my block. Then it was back to being a turd.
I have a new piston ring headed my way and a hone. I will keep you all in the loop. Feel free to throw in some knowledge I am new to these horizontal engines.
These springs on the exhaust header... I do not recommend taking them off. It is way easier to remove the bolts from the jug. Those springs are as tight as red clutch shoe springs, naturally I took them off instead of the bolts. I thought it was going to be "faster".
