Honda dio af28 topspeed
Guys im just gonna ask what is the possible topspeed for a af28 dio with street setup? can it hit 70mph ? thanks for the reply
Re: Honda dio af28 topspeed
wow thanks for the reply here in the philippines i have seen personally a 50cc dio that can hit 120 kph but he didnt share all the specs but i believe its the porting that gave it the topspeed..
what can you tell me about this parts/... full volume crank stock stroke balanced gears 15x42 2ndary 24mm carbs oko ct manifold kelly pulley 45 deg td kas pipe exhaust.. what tops should i expect in this parts with a 50cc?
i dont have access to a any malossi or polini parts here all i got is taiwan parts..
