this is how i mounted the engine
picked up two of these air cylinders at a local swap meet for 10 bucks for two. ill only be using one
and this is the start of my air ride setup
heres how she sits
viair compressor ill be using
i shaved and polished stock controls. the kill switch turns the compressor on raising the bike up and the starter button dumps air out
start of my headlight
used the stock handle bars and flipped them
then filled and sanded the gap
let the hate begin. i love the japanese bosozuku style in some areas so i made this exhaust
which leads me to a question that i cant figure out
i hook up the ecu and harness from a 12 ruckus to go along with the 12 ruckus engine. and now with a jump pack at 12.9 volts i hit the sarter button and all i get is a rapid cilcking from the starter relay. i have one ground from the harness to the steering neck(frame) and another at the back from the harness to the cvt case. those are the only two grounds i see on the harness. can any please help so i can move ahead on this and get it running
