More pics of my stroker setup
Added the pg big stroker pipe , need to rejet my mikuni 38mm carb but this pipe is insane it honestly was worth the wait and cash this thing is great !
Re: More pics of my stroker setup
Pg big stroker race pipe
- image.jpg (135.46 KiB) Viewed 7196 times
- image.jpg (124.07 KiB) Viewed 7196 times
I am very happy with the fitment on the pipe , btw yes i am runing a cooling shroud its not on due to tuning and things of that nature
- image.jpg (173.38 KiB) Viewed 7196 times
Im runing a 370 main jet on my mikuni and it is still runing too lean must be the air mixture but these were quick pics because it is freezing up here in jersey
- image.jpg (84.78 KiB) Viewed 7196 times
My mikuni tmx race carb this thing is a beauty
- image.jpg (84.58 KiB) Viewed 7196 times
Spooneg6, what brand crank and cylinder are you using? Did you modify the cases yourself to fit the stroker parts? That big PG pipe is sweet looking and that carb is very nice!!
78 Honda Hobbit Athena
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
I know this but im waiting till mid april to ride aince it is too cold i want to rejet it at the temp were it should be on the streetgraphite9 wrote:it needs more fuel when its cold, you need to upjet if your going to run in the cold weather.
