Polini/malossi pulley
Can anyone tell me the difference between the two looking to buy one but could not find good close of pictures of the them. Or if anyone can compare it to a Keli pulley
Re: Polini/malossi pulley
And this is for a dio motor
Variator?
Outer diameter of the malossi for ruckus that fits dio is 97mm. Polini 94. Ramp angles maybe different, but I dont know if fine tuners could distinguish the difference. Keli is around 90mm
98 Elite
4 strokes are for cars
use the PG billit front face!
I can. They are from VT Cycles http://www.ebay.com/itm/Phongeer-Hi-Per ... 1701549649DirtyE wrote:Maddog, could you provide a link?
Thank you. If I didnt already have a alu drive face coming from g9 I would certainly buy that.
98 Elite
- Rip_City_Spree
So basically using the Alu one just makes things lighter right? That and the clutch bell are about the thing on the motor I haven't changed yet. How much does it help?
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
The effects are very small. Individual you won't feel, but all things together have an impact. Cases flowed, lighter parts, port and matching.....
I just need one that will fit on my malossi crankshaft without play
98 Elite
The larger diameter of the front pulley increases the belt-controlled "gearing", like a bigger front sprocket on a bicycle will be harder to pedal, but in theory capable of higher top speed. Like a bicycle, the actual realization of that higher speed depends on the horsepower available from the engine. (or Pedal-Pusher). You can gear things up to the moon, but if the power isn't there, it won't go any faster. In fact sometimes it goes the other way.
Polini for DIO/AF16-18 is up 3.5mm from stock (87.5mm, methinks) at 91mm. Polini for Ruckus is 94mm, but you have to shave the crankcase at the starter housing to clear the bigger circle. Malossi-for-Ruckus is 97mm, so you have to shave a bit more. Both Polini and Malossi are great quality, trouble-free and long-lasting parts. The cheaper Keli worked for me just fine, but I don't know if they make one in the bigger "for-Ruckus" diameters.
- Rip_City_Spree
Thanks Wheel
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
