Oil Light Replacement
I would like to know how to replace the bulb in the oil level light. Does the lens screw out, pop out or what? Would like to know before I break something. I have tried to pry the lens off and unscrew it but no luck. Need some expert advice. Thanks Dennis
Re: Oil Light Replacement
Please tell us what model and year of your scooter...
It is a 1986 S Gyro and sorry I forgot to put that in. Thanks Dennis
luckyrabbit7
- Goped
I have a 1985 and the lens pulls out. It has a shaft with no threads. Its longer than you would think.
Thanks; I thought that might be but was unwilling to try with out making sure. I'm starting to restore this and seem to run into little things like this. Again Thanks Dennis
luckyrabbit7
- Goped
The lens pulls out of the rubber grommet, but still is attached to the wires.you then can push the gromment out ├Áf the cover , then the lens wil fit throught the cover.
Wow !!! Great picture now I just how to get it out. Thanks a lot.
