Why was the glove box cut open ?
~UNDER CONSTRUCTiON~
- cruzingratiot
to fit the triple tree for the disc brake swap
other pics in link here
viewtopic.php?f=20&t=27850&start=195#p265186
Donate Life
http://www.donatelife.net/
Thank You
Thank You
Oh yeah lol duh. That looks great! I would love to do disc brakes. The little drums are not very effective over 50mph
- cruzingratiot
modified a inner fender to keep the dirt out
now waiting on a custom brake line I ordered
than I can put it together
and hopefully ride it
50 degree temps are called for in Michigan for the next week
Donate Life
Thank You
Thank You
That is frickin awesome!
- Rip_City_Spree
Nice work!
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
What throttle cable are you using for the 28mm oko carburator?
- cruzingratiot
I don't know the part #96elite wrote:What throttle cable are you using for the 28mm oko carburator?
but in the for sale wanted section
one of these members can help you
graphite9 viewtopic.php?f=2&t=28312
Red Eft Performance viewtopic.php?f=2&t=19538
Donate Life
Thank You
Thank You
- cruzingratiot
disc swap done
now on to some other stuff than
the bike is going to need a good cleaning
than some better pictures master cylinder fit under the plastic like I planned
- ds.jpg (255.63 KiB) Viewed 8720 times
- rh.jpg (255.36 KiB) Viewed 8720 times
Donate Life
Thank You
Thank You
Awesome! Inspiration!
98 Elite
4 strokes are for cars
- cruzingratiot
put on the stage 6 intake really moves the carb closer to the center of the bike
and towards the front of the bike
there is lot more room from the carb to the side skirt
and my air filter fits a lot better
about 1/2 inch of clearance compared to the 1/8 inch I had before
the cons of the intake so far
I wont be able to change jets without removing the kick start cover
had to grind the top of the boss (red arrow)so the float bowl wouldn't hit
that is how far in the carb sits
kick stand fits really good took the center stand off (after the pic was taken)
other than that 50+ degrees Saturday
time to put some gas in it and ride
and stop a whole lot faster
a lot of repeated info for quicker future refrence
93 Octane fuel , (R+M)/2.
8.5 gears
24mm Polini pwk carb 128 main jet 45 pilot jet
JJH CARB needle clip on top
new malossi red contra spring 2000 RPM installed on Mon Oct 27, 2014 < didn't record miles
(refrence for above 5339 miles on odometer Aug 29, 2014)
variator weights 27 grams
polini 3 shoe clutch with 3g blue springs polini PN 245.072
naraku clutch bell
Windjammer exhaust
polini corsa 72cc
malossi crank
32-1 premix Klotz r-50
1470 miles on odometer when I rebuilt motor = 4,479 on motor
5919 miles on chasie to date
new front tire put on . swapped old front to rear at 4460 miles
so there is 1459 miles on front tire and there is 4,469 miles on swapped rear tire
new belt at 4255 miles on the odometer so there is 1664 miles on belt
8.5 gears
naraku clutch bell
Windjammer exhaust
polini corsa 72cc
malossi crank
Donate Life
Thank You
Thank You
- cruzingratiot
6007 miles on bike
Donate Life
Thank You
Thank You
- Rip_City_Spree
She's a beaut!
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Front end looks awesome!
