DR Pulley HIT Clutch
cruzingratiot
Post by cruzingratiot »
interesting concept instead of relying on the centrifugal force of the clutch alone
it also has a set of spring loaded pins that helps push the shoes out and keep the clutch engaged
sounds interesting
what do you think ??
test graphs
http://www.pulley-scooter-tuning.com/p/ ... plung.html
PDF on HIT clutch
http://www.drpulley.info/Pulley_docs/HIT_manual.pdf
Donate Life
http://www.donatelife.net/
Thank You
DirtyE
Re: DR Pulley HIT Clutch
Post by DirtyE »
I bought one for my piaggio powered sr50. BIGBNRG hooked me up with a great used price. I thought it was difficult to setup so I sold it and bought a malossi delta(which i had already learned how to setup).
98 Elite
4 strokes are for cars
1man8scoots
Post by 1man8scoots »
Did you get it to work? I saw one a while back for the sr50 also and wondered if it was a gimmick or real world dynamic.
DirtyE
Post by DirtyE »
It came very highly recommended. I didn't take the time to learn it. I get to a point where curiosity kills me. Mostly financially.
98 Elite
cruzingratiot
1man8scoots wrote:Did you get it to work? I saw one a while back for the sr50 also and wondered if it was a gimmick or real world dynamic.
did you look at the links ?
the one dyno test graph for the kymco 125
shows 2.01 N-m more torque than that from a stock clutch
I understand the concept but like anything else
time would be needed to fully tune it in
Donate Life
Thank You
