whining noise coming from rear sa50 elite
- Dustyn2007
- BMX
hello Im working on my dads 1999 Honda elite its been making a whining rubbing type noise coming frome rear end so I took gear cover off didn't see anything really noticeable but I went ahead and replaced the bearing for rear drive shaft and bearing in the cover still making noise gets louder the faster you go any ideas?
Re: whining noise coming from rear sa50 elite
Did you see any metal filings in the gear oil?Dustyn2007 wrote:hello Im working on my dads 1999 Honda elite its been making a whining rubbing type noise coming frome rear end so I took gear cover off didn't see anything really noticeable but I went ahead and replaced the bearing for rear drive shaft and bearing in the cover still making noise gets louder the faster you go any ideas?
- Dustyn2007
- BMX
No didn't see any filings it also tries to lockup Could it be the clutch by chance?
- Dustyn2007
- BMX
Re: Whining noise coming from rear sa50 Elite
Does anybody make a new rear axle?
After the new bearings still locking up rear tire.
The rear axle has some play in it.
Wondering if the play could be putting the gear in a bind??
- cruzingratiot
are the bearings in the rear belt pulley bad ??
you can get the axe new
http://www.discounthondaparts.com/fiche ... veh=131293
Donate Life
http://www.donatelife.net/
Thank You
Thank You
- Dustyn2007
- BMX
No it does it with clutch pulley off the bike Just rotating wheel by hand it catches feel like grabing
- Dustyn2007
- BMX
I seen that part but didn't know if it were just the gear or complete thanks
1man8scoots
Before you buy a shaft for no reason remove the gear cover and gears to check to be sure the bearings spin and the landing is not marred up. The shaft will not fix your problem unless it is bent. I've heard someone say they bent theirs but personally I've never seen it happen. More than likely a bearing has gone bad for the input shaft, that happens more than anything on these and kymco engines.
- Dustyn2007
- BMX
I just replace the bearing and still doin it I also replace bearing in the cover The shaft seems to have to much play in the bearing possibly putting gears in bind??? I don't what else it could be
Stock or aftermarket gears?
- Dustyn2007
- BMX
Stock gears. I think I found prob it the shaft that holds clutch not sure what it's called I tore my other scooter down and quit makn noise when I swaped it
