50x50 98cc stroker build
ped
Post by ped »
Hi forum.
I'm putting together a 50mm stroke x 50mm bore = 98cc stroker af16 motor for the summer.
A daily driver. :smile:
Most all the parts are Taiwan.
hope you enjoy the photos.
:geekdance: this is my first stroker motor build. it's going to be fun. :peace:
PG 50mm BBK
PG 50mm Crank
Honda bearings & seals
OKO 24mm Carb
Ct Mani
Polini for ruckus variator
Malossi ZX Belt
ZX drive pulley
V8 Pipe
Blue butt plug (aka oil plug) lol
8.4 or 7.5 gears (choice)
ped
Re: 50x50 98cc stroker build
Post by ped »
:smile:
PG Phongeer 50mm crank.
ped
Post by ped »
:nerd:
ped
Post by ped »
:nerd: the other side case. :geekdance:
ped
Post by ped »
:smile:
before
after
1man8scoots
Post by 1man8scoots »
Sweet! Chamfer those ports real good. Going to be exciting!
Downsouthdio
Post by Downsouthdio »
Sweet setup man,,what kind of crank? Kinda hard to find the 50mm cranks these days..this could be a dd stroker!!
Honda super dio
Corsa
26mm
Sparrow
Mini_Stroker305
Post by Mini_Stroker305 »
:thumbwink:
96 Yamaha Jog Next Zone CY50
72cc Polini Evo 2
Ruima 41.4 Teflon ministroke
Yasuni C16
24mm Polini pwk
Malossi 8:1 Primary Gears
Malossi VL14 Reeds
Polini 360 Mani
Jaingwayne transmission
Michelin S1 tires 90/90/10
ped
Post by ped »
:geekdance: thanks everyone. I think it's going to be a sweet motor. :smile:
ped
Post by ped »
:thumbwink:
ped
Post by ped »
:peace:
1man8scoots
Hi ped, I don't recommend you to leave the crank sitting on its side with only one arm supported by the case. I also don't recommend leaving them sit on a table. It's what happened to the malossi crank I gave you.
Did you have to bore your crank area to fit the 50mm or is it the one that just barely fits?
ped
Post by ped »
1man8scoots wrote:Hi ped, I don't recommend you to leave the crank sitting on its side with only one arm supported by the case. I also don't recommend leaving them sit on a table. It's what happened to the malossi crank I gave you.
Hey 1man8scoots. thanks for the advice, and thanks for the crank. I had it fixed, but it never really came out right. they told me to bring it back. :happy: I have something for you.
I had to bore out the crank area to fit the 50 mm. :naughty:
ped
Post by ped »
graphite9 wrote:wow ped, really nice work. Nice clean clear pictures, and your window portwork looks perfect. Kudos. :worship: What mani are you going to run? Hoping to have my 114cc finished up soon.
Mr. G. I'm going with a ct.
I'm going to make it a affordable build. :wink:
Post by swimmingfree »
hay ped sweet little build you got going there guy...
