The P.O.P. build
cruzingratiot
The P.O.P. build
Post by cruzingratiot »
I have a P.O.P. ( pile of parts )
The basis of this build:
To build a running scooter out of this
and parts laying around.
72cc, used Polini bore with new piston and rings,
8.5 gears, 28mm carb, ct intake, arrow rep exhaust,
and cans paint.
2001 elite dosent run. Bad wiring. :(
elite .jpg (236.16 KiB) Viewed 14355 times
Some of the parts.
Donate Life
http://www.donatelife.net/
Thank You
cruzingratiot
Re: The P.O.P build
low dollar build low dollar fix
how to get rid of plastic discoloration without painting
tools needed map gas torch and the guts to do it ( don't know if propane gets hot enough
Warnning proceed at own risk try on scrap part first
your basically heating up the top of the plastic
and melting it to get the color back
it isn't perfect but I think it looks better than before
Donate Life
Thank You
DeanP
Re: The P.O.P. build
Post by DeanP »
I used Novus plastic cleaner that I got thru Amazon. Worked well for me.
cruzingratiot
what do you do when you have
2 head light covers both crashed on the opposite side
and don't own a plastic welder ?
acetone (nail polish remover)
look up on youtube " How to fix plastic using only Acetone "
a dremel and some time you can fuze the broken plastic together
Remember this is a low dollar build
DeanP wrote:I used Novus plastic cleaner that I got thru Amazon. Worked well for me.
to far gone for that notice upper right corner it will get rid some discoloration from bent plastic
Donate Life
Thank You
cruzingratiot
the 2001 head light is plastic
well this one is in really bad shape
see if we can fix it
top right how bad it was
top left some filing and wet sanding
bottom some polish and buffing not bad for first try
will try again
( I do have a sealed 25 watt head light if this dose not come out better)
Donate Life
Thank You
DeanP
Post by DeanP »
Nice fix for the light! Looks good!
1man8scoots
Post by 1man8scoots »
If you're not satisfied with it I have a spare good condition sealed beam light I can send you if you pay shipping. I'd swap it out with the unsealed 01 you have tho.
patthesoundguy
Post by patthesoundguy »
I like P.O.P sounds way cooler than basket case. Gonna be great!
Xxbeejay45xx
Post by Xxbeejay45xx »
Wow you have a spare scooter and spare parts to go with it to build a wicked bolt on zipper, totally awesome!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
cruzingratiot
had a somewhat nice day outside so
time for some paint
Spray cans
Rust-oleum -Black night Metallic & clear
this close up makes it look more silver because of the flash
looks better in person than pictures
will take pictures outside when done
Donate Life
Thank You
Post by swimmingfree »
like the color.....
cruzingratiot
re sanded
and rebuffed headlight saved now on to turn signals
chipped cracked and scratched and broken mounting tab
lets see what we can do
with sandpaper epoxy and black out taillight film
the start the silver is where a piece of the lens was missing
Donate Life
Thank You
cruzingratiot
turn signals sanded polished tinted
cant hardly tell they were cracked or scratched
Donate Life
Thank You
cruzingratiot
some tape a vaccum and a dremmel a quick port of the intake
the motor is in
need to spend some money :x
don't want to run it without temp guage
so first money spent other than paint & paint supplies
Donate Life
Thank You
deuce217
Post by deuce217 »
Nice work, keep it up.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
