Re: Dio disc brake front on Elite frame
bonesv
Post by bonesv »
Thank you swim, 1m8s, ripcity, MS305, and ped! By the way, you guys have some nice builds going on as well!!! I think eventually I will do another one but I want to use the Daelim Cordi legs and disc set up. Much easier to get, and much cheaper too!!!
veedubh20
Post by veedubh20 »
honda sb50 with g stem is bolt on , no problem and no mod required..
Xxbeejay45xx
Post by Xxbeejay45xx »
Nice job bonesv. New way of doing a disc and headset mod.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
Xxbeejay45xx
veedubh20 wrote:honda sb50 with g stem is bolt on , no problem and no mod required..
Yes you are correct but for folks here on the mainland we need to be creative and make our own mods to work with what we gots. It's very hard to look for those parts here sir.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
bonesv
Post by bonesv »
Updated::::: We were able to shorten the front legs. This looks so much better now!
062 copy.jpg (56.08 KiB) Viewed 24767 times
064 copy.jpg (47.16 KiB) Viewed 24767 times
065 copy.jpg (50.71 KiB) Viewed 24767 times
Downsouthdio
Post by Downsouthdio »
One of my favorite bikes!! Beautiful ,awesome job b!
Honda super dio
Corsa
26mm
Sparrow
Xxbeejay45xx
Ahh dang looks much better, great job!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
S4Patrick
Post by S4Patrick »
NICE WORK!
Kool mirrors too.....what brand?
'92 Super Dio ZX - AF18 Corsa
bonesv
Post by bonesv »
S4Patrick wrote:NICE WORK!
Thanks Patrick! Those mirrors came from a local scooter shop. There was no packaging and he said he got them very cheap on ebay. Must be from china?lol.....They vibrate a lot when under way so I would recommend staying away from them. Constantly loosening, shaking, and small window of vision makes me want to toss them away. But, yes, they look Kool!
bonesv
Post by bonesv »
Well, it has been a while since this thread had an update so here is what's been done.......
I found a 200mm floating rotor and adapter kit to fit on my oem honda dio forks/wheel (10mm axle) and uses the same oem caliper. I did have to do some slight grinding for clearance here and there but it basically bolts up with no problems. Surprisingly, it was made in China, but I had also purchased another similar kit made in Taiwan and it has issues and does not fit correctly.
So far the product I have installed performs better than the oem honda dio 160mm rotor set up. IMO It now has better stopping power and there are no issues if it is correctly installed. If anyone wants to buy one of these 200mm kits for dio disc, please pm me for details. Bones
008 custom.jpg (119.39 KiB) Viewed 24652 times
009 copy.jpg (87.08 KiB) Viewed 24652 times
bonesv
Post by bonesv »
Yes, I have seen this done. It is not so for the sa50 elite. The sa50 elite must be modified to accept these stems. In reference, the G stem is same size as a metropolitan stem, and a dio zx stem, in terms of stem length and width of fork spacing but I believe you could use wheels up to 3" wide with any of these stems. I have also seen the G stem used without mods on an se50. Here is a pic of a "G" stem from a Dio G-Dash. And some pics of a Dio G Dash
035 copy.jpg (33.54 KiB) Viewed 24626 times
MrJumps
Post by MrJumps »
Ehat rental place is that? Looks like some 2 strokes for rent
2021 DRZ400sm :worship:
benji
Post by benji »
I think those are koso morrors, they look like a pair I have. Mine also look cool while moving around constantly and being hard to see out of haha. Nice bike bones
bonesv
Post by bonesv »
Lol.....naw, the Koso's don't do that. These cheap knock-off's do tho. But they're the only mirrors I have for this. I have not seen any that I would spend money for so this is it. I'm used to them now.
And thanks Benji.
@Jumps, there's got to be 20 or 30 places to rent scooters down here. This is a friend of mines' place that I stop by from time to time. As you can see in the pic he's closed for the day, and that's always a good time to crash a party!
benji
Post by benji »
Mine say koso on em, but they move around n the mounts broke. But ya I've got these and some stock ones, so I roll these haha. I looked and koso actually has alot of mirrors available. Here's mine. Image Image
