My 87 Elite 50 125cc stroker Build..
Hppowdercoatings
Re: My 87 Elite 50 125cc stroker Build..
Post by Hppowdercoatings »
Wheelman-111 wrote:Greetings:
Best-looking scooter I've seen in a while! Are you clear-coating over the decals, for the Cherry on the Parfait?
But is that a bare-nekkid cooling fan I see? I sure hope your're not running Shroudless!!
Thanks.. Yes Clear coat planned before Final Assembly.. No old shroud was broken, waiting on another one to get here..
ped
Post by ped »
Hi HP.
looks very nice :thumbwink:
Hppowdercoatings
Got the New Trail Tech Vapor Stealth Today..
Mounted it in the stock Gauge Location.. I think it turned out pretty good.. Now I just have to wire it up..
Hppowdercoatings
Changed up the Exhaust to a side bleed Style. A lot Quieter & no power loss.
Changed the 30mm OKO carb to 28mm OKO , could not get it to run & idle correctly.. Currently Setup 155/50 jetting. Still plan to swap to either a 28mm or 30mm Polini Carb. , they seem to be easier to tune and run Cooler. Running good enough I've started doing some Trans Tuning.
Right now running Polini white Center spring/Green clutch springs & 6x7g rollers , & 9:1 Gears..
This thing is Scary fast , any more then 1/4 throttle and it Turns into a one wheeled Uni- cycle...
Time to swap to some 7:5:1 Gears..
Hppowdercoatings
Fixed the front Disc issues. Powder coated wheels Custom gold metallic...Installed a new Polini 28mm carb from G9 , And set of 7.58:1 Gears from Wheelman-111... Now time to get some Seat/Tune Time..
1man8scoots
Post by 1man8scoots »
I like the color!
whitey
Post by whitey »
How's your tuning? What temps are you seeing?
78 Honda Hobbit Athena
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
