Speedo not registering
Nighttrain ex
Post by Nighttrain ex »
As of about 1 PM my speedometer is not registering my speed anyone who can give me some insight would be greatly appreciated.
Thanks
Is the cable turning from the front wheel?
Nighttrain ex
noiseguy wrote:Is the cable turning from the front wheel?
Its a 1999 Elite. I believe it turns the from the front wheel. I took of the front fairing to see if anything was cut or broken and everything seems fine. It worked on my way to school and then just didn't when I left. Everything else works in the gauge pod though? :?:
se50
Post by se50 »
Don't crash while doing this-
Take the cable off the speedometer, and move the thing (push it, drive slowly, etc) and watch the inside of the cable. Chances are, I'm guessing, it snapped.
1982 Volkswagen Rabbit 4dr 1.6l diesel (5 speed)
1987 Honda Elite SE50p with drilled out main jet, shaved head, UNI filter
1985 Kawasaki Bayou 185 ATV
1984 Yamaha IT200 enduro
1974 Piaggio/Vespa Ciao moped, pocketbike exhaust.
ADNOH
Post by ADNOH »
Sometimes mine stays at zero, but it wakes up if I spank the instrument!
RM
se50
Post by se50 »
The Kawi KE100 enduro doesn't pick up until 20 or so.
maddog
Post by maddog »
Take off the screw that holds the speedo cable if the cable isn't broken then take off the front wheel and grease the drive gear inside the brake hub, this should be done every yr. which most riders fail to do, my cables are original on all my scoots- Hey "TEXASS" can you ride what i build :lol:
