I have one of those, got it last year. Installed it on either my aero 80 or my af18. I think it was my aero 80, and it really diddnt do much in that mild un-wild bone stock motor. Might work wonders in my af18 with the ripping it does with all of the crazy bottom end launching I do with it it has the heavy red malossi center spring in it. That little yellow thing is still sitting on my bench from a year agoped wrote:hi guys. this is the one I have from Malossi.
has anyone seen real benefits from using it? I've never had binding problems.
center spring saver
- patthesoundguy
Re: center spring saver
I dont think it can hurt anything. Its $7. Why not? Thats cheap placebo!
98 Elite
4 strokes are for cars
As a friction damper, it may help to quell tangential vibration - back-and-forth buzz around the circle of the spring. Vibration is what fatigues metal more than the physical compression forces, so it may in fact be a "spring-saver". By its relatively low friction, it may keep the spring from winding up and unwinding as the cams do their little twisty thing. The ball-bearing variety I've used for years does the same thing, but the grease dampens the vibes. Couldn't hurt, and also raises the preload a hair, though I doubt it's enough to warrant changing the roller weight load.
Or you can go super cheap and use construction washers and custom grind them
1man8scoots
Only if you're poor and live in your mom's basement.
Had mine 20 yrs. ago, the construction washer is for all cheap people on this forum
1man8scoots
You're right about that.
- Rip_City_Spree
According to fancy drawing you get it goes on the clutch side. And yes this is one part I'm gonna keep a fresh one in there. Gonna pull mine and see how it's doing. I've got maybe 300+ miles on it.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
From the horses mouth
- 20150518_121847.jpg (167.36 KiB) Viewed 7875 times
98 Elite
1man8scoots
That's a torsion controller, similar to a spring saver. The radial ball bearing supports are the ones that go under. Torsion controls and spring savers go on top. Spring savers don't do much.
1man8scoots
1man8scoots
And here folks is commonly referred to as a a a a spring saver a say you. You put this darlin on top o the spring but under the clutching area.
1man8scoots
1man8scoots
Maddog please post your paper washer mod, I showed how a polini saver and support looks like in real life.
Go to page 2 to see the polini lower spring support and it's complex installation.
- Rip_City_Spree
Thanks 1man
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
