01 Elite SR "GOOCH"
1man8scoots
Re: 01 Elite SR "GOOCH"
Post by 1man8scoots »
Don't give up. I've been tuning for years and I'm having some issues with the fabrizi cylinders. Sometimes there's just days you have to walk away and come back later when you're able to have more patience.
ped
Post by ped »
Hi RCS. Sounds like you're not getting enough fuel?
Rip_City_Spree
Post by Rip_City_Spree »
My next move will be a bigger MJ probably a 106 or 108. Leaning it out isn't working so I'm gonna take it out Sunday and change jets and we shall see. Gonna try to connect with g9 and let him ride if he's around to see what his thoughts are.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Put in the 106mj and its a lot better. Temps are higher. So I might still be a little lean. Will need to adjust my pj as its wanting to stall occasionally coming to a stop. But overall it's better thankfully
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
just quick pic after a night of work for the bike
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
johnny248
Post by johnny248 »
Any updates?
~UNDER CONSTRUCTiON~
Rip_City_Spree
Been raining. i have moved the clip back to center temps were pretty high on hill pulls. Think the 106 MJ was still a little lean so hoping to resolve both. Gonna have to change my pj out also I'm sure. Will keep posting if I ride. The next 2 weeks are supposed to be nice.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
DeanP
Post by DeanP »
What's your max rpm under wot throttle?
Rip_City_Spree
With 5.5g rollers and still running a bit off in the carb I've recently had up to 10800 rpms but oddly my speed was only 59mph. Honestly though I've yet to see this max out mph and rpm wise. Now that she's close to tuned I'm gonna get it dialed in and try to get it on g9s Dyno at some point to see what she can do because I doubt I'll be able to do it on the street.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
took the bike out for a quick ride at lunch. I moved the clip back to center to see if the bleed over would help the MJ. glad to say there was maybe a very slight hesitation around 45 but it didnt slow down and kept pulling. I probably wouldnt have noticed it if I wasnt so used to expecting it to happen.
I sitll have some flutter on accelleration and its popping a bit on decel. I am going to try to adjust the PJ to help with that. I did finally adjust the air screw on the carb to get a better idle. was less than a quater of a turn in to get a good solid Idle at 1800 rpms. thinking I might try to lean out the PJ a bit to see what that will do to the needle. I moved the clip down to center as I felt it was running warm at 3/4 throttle on long pulls. so I was trying to bring that down. I will be taking her on a long ride on sunday across town so I will have a better idea whats happening then.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
DeanP
Post by DeanP »
Looking fwd to your results on the dyno!
Rip_City_Spree
Me too not sure when that's gonna happen.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Put 26 miles on the bike today. Ran pretty good having some issues on decel coming back to idle wants to stall out on my. Thinking its a bit rich on the pj. Gonna drop it down one and give it a try.
WOT up hill for a long pull got to 378 at high 50mph and pulling hard. Blasting by a stockish ruck as he was tucking.(always fun)
Still getting warm pulling up hills but don't think it'll get much over 380. That said it pulls hard up any hill I've put it up so far.
Need to up my weights with 5.5g all around it's keeping my top speed around 58mpg.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Yeah it will get over 60 when I up my weights a bit I have no doubt. That 58mph was mid 9k rpms
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
You guys riding out in Oregon city? At some point I'd like to compare the 2 pipes. Let me get the long dialed I. To get a good base.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
