How to revmove bolt to get to variator?
No i don't have an impact wrench. Bought a tusk clutch removal tool but couldn't get it to work, kept slipping off the teeth of the drive face. It worked to remove the bolt holding the clutch bell but not the bolt to get to the variator. Am I doing something wrong here??? SOOOO Frustrating...
My scooter is this color, and I like it.
97 Elite SA50
97 Elite SA50
- Rip_City_Spree
Re: How to revmove bolt to get to variator?
Harbor freight I think it's a filter wrench looks like a vise grip with round area with teeth on the other end. $8.00 I'm on my second one needs to be almost all the way open to clamp. But that's what I use.
- image.jpg (82.49 KiB) Viewed 4715 times
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Battery impact driver is well worth the money considering how many times you'll end up using it
Honda DIO 3 ZX Live, Malossi, WindJammah!
- Rip_City_Spree
I use this so I don't have to carry an impact wrench around in my scooter. And I can still adjust anywhere I want.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Also is the push start motor suppose to be able to pull right out because mind kinda fell right out when i got the crack case off?
97 Elite SA50
97 Elite SA50
The part that fell out is commonly called the starter Bendix, and it is held in place by the Belt Cover. The Tusk pulley holder , an oil filter strap wrench, or any means to keep the crank from turning will allow removal of the Drive Face nut.
kennedy759
- BMX
if you want hold the crank from moving, take out spark plug and fill the cylinder with clothes line, then turn the crank until the piston is held tight against the rope and cylinder head, when done pull the rope out. learned this when removing clutches from snowmobile a long time ago in a land far far away.
